Eu queria testar um VA também, mas é foda, é o painel mais lentoTa dificil um monitor sem problemas heim, ainda mais high end, quero gastar e nao tem um decente po
VA vs ips
Esses vídeos são gold demais, tudo que muitos reviews profissionais deixam passar ou não mostram com detalhes
Expert1 semana atrás (editado)
have you played on other monitors with va panel? probaly all of them have that problem. try different overdrive settings. its normal that piksels in dark scenes move slower in that panels. i consider buy that monitor but wonder if that efect is worse than usually...
Darcy Parkinson
1 semana atrás
Ive sold the monitor and bought a new one. I purchased the Asus TUF vg27aq and the issue is gone. It was definitely the slow VA panel causing the issue
NxB6 dias atrás
Is it better on the ips panel or the tn?
Darcy Parkinson
@NxB the issue is gone completely gone on both ips and tn. I am using a ips right now Asus TUF vg27aq
NxB
@Darcy Parkinson do you recommend the g27q? Its an ips panel with 144hz
Darcy Parkinson
@NxB I don't want to recommend anything I haven't used personally but I would say that by default it will perform better than the VA just by being an ips
NxB6 dias atrás
@Darcy Parkinson i think im going to buy the g27qc or the g27q because of the low price for its features but idk this is the first video i see about an issue in this monitor
Darcy Parkinson
@NxB I highly recommend you try the ips panel first and if you don't like it return it for the VA
