tb ja estou com o meu codigo!!
e no aguardo pro iracing 2.0!!
To muito ancioso para o lançamento do iRacing 2.0, promete muito!
O que tem hoje as 21h?
Testei aqui o Ford GT em Suzuka. Achei muito bom esse New Tire Model. Tu sente o pneu no asfalto legal, só não saquei esse cambio dele. É sequencial, mas pra reduzir precisa da embreagem? Alguem pode me explicar?
Ae Amigos, comecei faz um mês a correr no Iracing e estou muito satisfeito com o serviço, ganhei 3 meses grátis para testes e com certeza vou ficar depois deste tempo, ontem mudei minha carteira para D, gostaria de sabe se tem mais pilotos no mesmo nível que o meu para treinarmos. T+
The recent iRacing 2.0 build included a new feature to let you adjust the damping level on your force feedback wheel. Damping introduces a stabilizing force, feeling a bit like stirring a spoon in honey. This value used to be hard coded to 75, but now you can change the damping level from 0 (off) to 100 (full on). Due to a small bug, the level was reset to 0 for most of you in this new build, which may make the cars feel different than you expect when driving. iRacing recommends that you run your force feedback with damping turned down to 25 or below, as that gives a more precise feel while driving. But if you would like to restore the feel of the force feedback to the way it was before this recent build, you should return the damping to the old default of 75. You can find the new damping adjustment by clicking on Options while at the main screen, then selecting the Controls tab.
EDIT FOR IMPORTANT NOTE:
Thanks to member Colin MacLean for pointing out:
If the damping force was/is set to ZERO in the windows driver the in-game slider will have no effect as damping is turned off. If you previously had damping set to ZERO in the driver you always had damping off (zero) so in this build it will be no different. If you wish to use damping in this build you have to set the damping slider in the driver to 100 thereby enabling damping in the sim.
parece que o FF tb sera mudado radicalmente com a versao 2.0
Vcs deixam algum config no driver do G27 em spings? ou deixo 0?
e voce ta configurando como?
nunca mexi nessas regulagens
