Mano, se eu fosse você eu perguntava na loja q vc comprou se o firmware do monitor que vc comprou já foi arrumado e atualizado pela AOC, pq os gringos estão loucos com esse monitor porque tava com problema no freesync que ao usar freesync desativa o overdriver e alterando o tempo de resposta, acho que só tendo freesync pra testar, mas a única solução pra arrumar isso é enviando pra RMA da AOC que eles vão lá e atualizam o firmware do monitor, talvez seja até bom vc enviar ele o quanto antes se ele tiver esse mesmo problema que a galera ta falando .
Voce que comprou o monitor também da olhada no que falei pro amigo acima .
e vc também rs
FONTE 1: REVIEW DO PRODUTO:
Cons: Freesync flat-out will not work without the drivers, it will distort the monitor to the point that you are forced to reboot and will cause all kinds of trouble.
I don't have a CD drive because I haven't needed one for almost 5 years now considering every retailer I have ever purchased from has put their drivers on the website itself.
Overdrive does not work at all, is completely grayed out so I got an old firmware version of the monitor and it is being improperly advertised as a 1 to 1 response time.
If my issues can get fixed (contacted support almost a week ago and no word yet so not a good sign) I would gladly raise my review sense the monitor is good, just has some funny issues and poor support thus far.
FONTE 2: REVIEW DO PRODUTO
Pros: solid build quality (on the outside)
Cons: does not work as advertised.
besides the fact its suppose to be a 144mhz freesync compatible monitor with a 1ms response time, it is not.
running this monitor in 144hz disables overdrive, which essentially kills your response time.
an AOC customer rep stated on another website about a month ago, that all stock had been recalled and they were going to fix the firmware, I figured it was safe to order this from newegg a month later because of course newegg would have the new fixed stock right? nope. I got a monitor that was supposedly recalled a month ago, shipped to my door.
Other Thoughts: people I am just trying to warn you, this is very shady by AOC to flat out admit the problem, and claim to have fixed it.. and yet a month later still getting old bad firmware monitors that don't work as advertised from a major retailer like newegg.
4 out of 6 people found this review helpful. Did you?
FONTE 3 (REVIEW DO PRODUTO):
Cons: Well I am returning the product because it does not do 144hz without display problems. I tried the driver it came with and the beta driver which was a pain to install because it is not a certified driver. This ment that I had to reboot win10 without driver verification (You kidding me). I left a message with their tech support but no call backs. Gamma is way to high and is a pain to adjust. I get little horizontal lines moving upwards on the monitor when its set to 144hz more noticeable in games because its seems like the colors are moving. Overdrive is disabled with either driver @ 144hz.
Expensive for something that has only beta drivers that are supposed to get the monitor to perform at advertised specs.
Other Thoughts: Don't waste your time. Wait a little longer for a better monitor from them or buy a different brand. Not worth 250 bucks
Então recomendo a quem comprou e a quem vai comprar realmente dar uma olhada nisso, também estou interessado em comprar mas vou esperar mais um pouco pra ver se os monitores que chegaram aqui no Brasil estão com este mesmo problemas ou se serão arrumados
