Eis a questãoOk, rom do omar instalada.
Como tira o aviso do bootloader desbloqueado?
Alguem aí usa tapaltalk 2 e está com dificuldades para acessar o adrenaline?
Já Estou Sem Esperanças Pra Desbloquear Meu Bootloader Não Estou Conseguindo Já Fiz de Todos os Jeitos e Nada
Alguem Ai que Já Desbloqueou tem a Mesma Versão Que Eu?
982.50.20.XT890.Brasil.en.BR
9.8.2l-50_SML-20.20
Já testou com todos os navegadores?
9.8.2l-50_SML-20.20
Segue o tutorial, e quando aparecerem os numeros no cmd, vai no menu>>marcar seleciona os numeros, cola no notepad, apaga os espaços em branco, seleciona tudo, copia e cola na pagina da motorola.Já Estou Sem Esperanças Pra Desbloquear Meu Bootloader Não Estou Conseguindo Já Fiz de Todos os Jeitos e Nada
9.8.2l-50_SML-20.20
The following changes are incorporated:
- http://forum.xda-developers.com/showthread.php?t=2174731
- http://forum.xda-developers.com/showthread.php?t=2174731Custom optimized kernel with SmartassV2 CPU governor set to default, but more to choose once booted.
- Different IO Schedulers to choose from, the default is ROW.
- Android 4.2 Gallery with effects working using native x86 libs.
- Android 4.2 Camera (and also the Motorola's stock camera was left there) with working panorama.
- Android 4.2 Clock with timer and stopwatch.
- Android 4.2 Keyboard with multi-lingual support and swype gestures working.
- Apex as the default launcher -- goodbye Blur's HomeScreen (check the extra flashers if you want to keep Blur's home).
- A lot of Blur services and Motorola stuff removed for better memory consumption and less background services.
- Very good battery life.
- Comes pre-rooted and with Koush's x86 Superuser.
- Tweaked the UI compositor, no more lag.
- Auto brightness curve tweaks mod for better levels while indoors.
- Fully deodexed and zipaligned.
- init.d support implemented inside the ramdisk of the Kernel.
- Kernel memory/cache management optimizations and scheduler power-savings.
- CyanogenMod Email/Exchange client instead of Motorola's.
- AOSP MMS Messaging application.
- Option to make the External SD the primary one under flashable extras.
- adb runs as root. (ie, "adb remount" now works).
- DPI changer app work on this ROM.
- Hold up/down keys to move between music tracks when the screen is off, thanks to @shaftenberg.
No primeiro teste dava errado o meu também, depois de seguir esses passos consegui desbloquear.
Coloquei a rom do Omar, ficou mais rápido o celular, alançou o segundo posto no Quadrant, perdendo apenas pro HTC One
ROM do OMAR atualizada!
[URL="http://haxr.org/omar/android/RaZR%20i%20-%20XT890/MISC/screenshot.png"]http://haxr.org/omar/android/RaZR%20i%20-%20XT890/MISC/screenshot.png
Galera,
Instalei umas duas versões do Igo, porém, ficou sem voz.
Instalei o Lockeando e a mesma coisa.
Instalei o Svox (ou algo parecido) e nada tb.
Acabei por tirar o Igo
Será que fiz algo errado? :trollfail:
Tem que configurar o tts...Ninguém?![]()
Como tá o GPS? Tá localizando fácil?
Pois é.... fucei em tudo e não ia.Tem que configurar o tts...
instalei a rom do omar e o gps parou de funcionar
tive q voltar pro 4.1.2 oficial![]()
Depende do local,se foi na parte traseira dá pra trocar sem gastar muito.A parte frontal nem vale a pena, o display faz parte dela..Gente uma duvida , meu celular caiu no chão e ficou com aquelas marcas de amassada no alumínio (igual estar acontecendo nos iphone 5) , o de alguém aqui aconteceu isso tbm ? e se da para reparar ?
http://imageshack.us/photo/my-images/705/snapshot20130604.jpg/
Ta assim ele . queria saber se tem como da um jeito porque me incomoda
