DrDreh, obrigado pelo review, fiquei mais empolgado para comparar o note.
Você poderia postar um print de tela com as notas que o Windows atribuiu ao PC?
Quero comprar essas notas com o meu PC atual.
Abraços
Eu não entendo nada disso, mas uma quick search de how to confirm IPS screen no Google me trouxe esse resultado:e continuo perguntando, existe software pra comprovar isso?
http://forums.lenovo.com/t5/X-Serie...tell-if-the-system-has-IPS-screen/ta-p/577443
update no 2º post...
vídeos de perfomance de jogos no mesmo modelo:
http://www.youtube.com/watch?v=pBj1bfEiHTM
http://www.youtube.com/watch?v=DrBYDoWbBXE
http://www.youtube.com/watch?v=_Wu42-3cxZk
http://www.youtube.com/watch?v=awwv0oOGY7E
http://www.youtube.com/watch?v=MiCPiJjFxSQ
http://www.youtube.com/watch?v=MHe0VfJzkRE
The display of the Acer Aspire V5-573 is a matte IPS panel from AU Optronics with a resolution of 1920x1080 pixels. You can even use the display under direct sunlight thanks to the maximum brightness of 311 cd/m². We determined the lowest brightness of 239 cd/m² in the lower right corner. This results in a brightness distribution of just 76%, but that is barely visible due to the sufficient luminance.
We really have to emphasize the excellent contrast ratio of 1,301:1 that is enabled by the low black value of the IPS panel. Ex-works (pre-calibration) we determined a yellow cast, but it was minimized after the calibration and not visible anymore. The color temperature of 6340 K is also close to the ideal value of 6500 K; only the gamma value deviates significantly from the ideal value (2.2) with 2.7. The black value of 0.22 cd/m² is excellent and results in crisp blacks without a visible gray film.
The Acer's coverage of the available color spaces is on a very high level. With more than 90% of the sRGB color space, the IPS display of the Aspire V5-573 is superior to most TN-panels. 61.8% coverage of AdobeRGB is also very good.
Web browsing in the park or on the terrace is no problem with the Acer Aspire V5-573. Thanks to the high contrast ratio and the high brightness of the matte display, you can even see the display content under direct sunlight. As a result, you can adjust the brightness in the shade and still see web sites or the Windows 8 interface.
As expected, the viewing angle stability benefits from the IPS technology. Colors remain stable even with viewing angles from the side and the brightness is just slightly reduced; watching movies with several persons should not be a problem.
cara sinceramente não sei, mas tenta fazer com esse procedimento abaixo:
Abra o Painel de Controle > Opções de Energia
Defina o Plano de Energia Alto Desempenho como padrão e clique em OK.
Agora, abra o Painel de Controle da nVidia e clique em 3D Settings > Manage 3D Settings
Localize o item Preferred graphics processor e defina “High Performance NVIDIA processor”
Clique em Apply, e reinicie o Computador em seguida.
estão enviando, mas pesquisei no forum do notebookreview e muita gente usa a de 90w por ser mais leve pra transportar, a de 120w é maior e mais pesada.
deu certo nao rsrssss
nota 5 pro video... sera q ta certo?
depois do envio, demorou quanto tempo pra chegar?
Colega, essa sua fonte está totalmente fora, a correta é 19,5 V , 6,15A e 120w. Muita sacanagem hein da Powernote, e o pior é que continuam querendo te enrolar e ainda mais pior é que se vc for no Procom com essa nota que vc recebeu, nem eles vão poder fazer nada.
Eu no seu lugar verificavas direitinho se essa tela é de verdade IPS, vai por mim, vc terá uma grande surpresa.
