Originally posted by haavard:
This is the third release candidate for Opera 10.51 for Windows. It fixes the following issues:
Fixed CARAKAN-1187 (Crash when scrolling page)
Fixed CARAKAN-1191 (Date pickers on several travel sites fail)
Depois que você adiciona um feed no Opera (como o wmh disse, clicando no icone que aparece na barra de endereço), vai abrir a página pra você escolher onde adicionar o feed, é só escolher opera mail. Pra ver os feeds é só clicar no O e ir em Feeds.Eu lembro que uma vez, no Opera 10 eu conseguia ver feeds pelo Opera, mas nao lembro como era..
cmo fas//
Vim só pra postar isso, você foi mais rápido xDnova build, 10.52
http://snapshot.opera.com/windows/Opera_1052_3333_in.exe
Changelog
Attempted fix for DSK-287066 (E-mails, attachments and pages don't open due to corrupted cache)
Fixed CORE-28588 (Network problem when using proxy)
Fixed CORE-28533 (EnableOnDemandPlugin causes NSL (Never Stops Loading))
Fixed CORE-950 (selectedIndex wrong after removing all options but one from SELECT with size set)
Fixed CORE-5926 (Option unselectable if another option removed and SIZE but not MULTIPLE set)
Fixed CORE-8930 (Support any HTTP verb in XHR, with exceptions)
Fixed CORE-24158 (Zimbra crash)
Fixed CORE-25585 (selectedIndex is -1 after adding option)
Fixed CORE-26939 (Option element crash)
Fixed CORE-15621 (Wrong option selected when removing selected option)
Fixed CORE-26314 (ContentEditable div inserts BR tag inside itself when added to dom tree)
Fixed CORE-11792 (Width and height of image in display:none element is 0 (Orkut avatar))
Fixed CORE-26940 (Zero size redirect fails)
Fixed CORE-26315 (Progress bar doesn't disappear when document fails to do document.close)
Fixed CORE-26405 (Image onerror event regression)
Fixed CORE-22236 (Enabling designmode removes event listeners)
Fixed CORE-25558 (XMLHttpRequest response referer wrong when request initiated in call from another frame)
Fixed CORE-22687 (Incorrect precision on negative numbers)
Fixed CORE-24822 (Improving setTimeout and setInterval precision)
Fixed CORE-28141 (Opera crashes after running Gordon for a while)
Fixed CORE-28451 (Fix to make windowless QuickTime work)
Fixed CORE-27676 (Crash with many connection attempts over proxy)
Fixed CARAKAN-1111 (Setting location of https iframe from different server)
Tem um cara falando nos comentários que agora tem a opção de ativar a aceleração por hardware pra testar no opera:config, baixei pra testar, só falta instalar.
O que o colega alvarogd comentou no tópico oficial do chrome tem razão de ser. Usando aqui a versão 10.51 3315 o navegador tem tido travamentos, lentidões e crashes e um consumo alto de memória e agora também inventou de não carregar e/ou não conseguir se conectar com algumas páginas.
Testo com outro navegador e as mesmas páginas carregam sem maiores percalços.
Entendo que estas situações fazem parte de softwares beta. Fica o relato de que nem sempre tudo funciona as mil maravilhas.
Parece que o cara imaginou coisas na lista do opera:config :slap:no opera:config tem dezenas/centenas de opçoes, onde exatamente tem essa opçao de aceleraçao por hardware?
Aqui tá acontecendo a mesma coisa que o wmh relatou.
Ontem quando cliquei pra abrir o Ópera, iniciou a instalação do 10.51, achei estranho mas deixei rolar. Logo de cara percebi uma lentidão fora do comum, e os travamentos estão me tirando do sério...
O consumo de memória está altíssimo, chegou em 246.0365k e agora está em ~136.768k!
O que eu faço? Será que reinstalando resolve???
Não estou conseguindo abrir o fórum pelo Opera, somente pelo FF...
Mais algumas pessoas andam relatando esses erros que as páginas nao abrem, ou abrem pela metade.
Alguem mais com esse problema?
Pessoal, aqui o Opera não salva as informações digitadas em formulários web, mesmo eu mandando salvar senhas e logins em vários sites. Alguém sabe como resolver esse problema ?
Tô usando aqui a versão 10.52 build 3337.
