NOVIDADES!
Alguns caras fizeram um "data mine", procuraram coisas nos arquivos de pre-load do jogo e acharam algumas informações interessantes sobre armas, missões, craft e etc.
Vídeo explicativo:
Lista do que contém no vídeo:
- 1) DLC weapons- these aren't confirmed but they were the only weapons in the files with DLC tags, so read that as you may
- 2) We now have a full mission list featuring 28 missions. One of these is a Brooklyn mission called 'Precinct Siege' and the other is called 'DLC KILL THE TANK', which I think we can pretty safely assume relates to the recent footage we saw of the Tank enemy.
- 3) We start the game in Brooklyn.
- 4) Daily missions are confirmed to award Phoenix points
- 5) There is an animation file for deploying claymores even though there are no claymores in the game. This could be a future ability/item
- 6) Safe houses provide map updates, matchmaking and vendors
- 7) It's highly likely that crafting items will produce items with random stats, so we'll need to keep crafting till we get the roll we want/need. Alternatively if it's gear (not weapons) we can utilize the Re calibration system...
- 8) Recalibration system lets you 'reforge' an item so that you change one stat on that item for another. It only affects gear (not weapons). Once you change one 'stat slot', that stat slot is the only one you change again. Each time you reforge the same 'stat slot' it costs more resources (unclear what these are but likely credits + crafting materials
- 9) There is a cheeky Doom easter egg in the game files- I found an assault rifle named the 'BFG 9000'. Unlikely but here's hoping
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
"Resumo" em HUE mode:
- Duas armas com DLC no nome do arquivo. Não tá confirmado, mas
talvez sejam armas das DLC's;
- Lista com 28 missões do jogo. Uma dessas é no Brooklyn chamada "Precinct Siege" e outra "DLC_Kill_The_Tank" que deve ser o que foi visto no trailer;
- Iniciaremos no Brooklyn (praticamente certo que sim);
- Missões diárias que darão os "pontos Phoenix";
- Arquivo de animação do personagem colocando Claymores. Mesmo não tendo no jogo, talvez o acessório seja lançado mais pra frente
(OU isso é apenas sobra de produção que não removeram);
- Safe Houses com atualizações do mapa, matchmaking e vendedores;
- Provavelmente os itens
craftados darão status aleatórios, mas vai ter que ir
craftando pra chegar no resultado que quiser;
- Recalibração deixa o jogador "recriar" o item e então mudar algum stat do item por outro, apenas para equipamentos (gear), não para as armas. Gastaria créditos + material para criação (craft);
- Tem um rifle de assalto chamado "BFG9000" que
talvez seja um easter egg referenciando o jogo Doom;
- Em outro post, um cara disse que foram encontradas referências de 138 armas nos arquivos do jogo.
Tem mais coisas tipo script da história, informações nos arquivos sobre waterplanes, helicópteros com minigun, etc... Tudo na Fonte 2.
Fonte 1,
Fonte 2
EDIT:
PROVÁVEL SPOILER!!
Postaram um provável vídeo de abertura do jogo. Essa "
cinematic" explica um pouco sobre o vírus... Enfim, eu não tinha visto isso antes, tirando os outros dois trechos do final (aquele da mulher se escondendo dos Cleaners e tal) que já haviam aparecido em trailers. Então,
TALVEZ isso tenha sido extraído também dos arquivos do pre-load.
Não garanto a veracidade disso aí, mas se não gostam de spoilers, não assistam.
Vídeo:
