AMD Ryzen™ Chipset Driver Release Notes 5.05.16.529
Article Number
RN-RYZEN-CHIPSET-5-05-16-529
Release Highlights
Known Issues
- Sometimes custom install fails to upgrade to latest drivers.
- Manual system restart required on Non-English OS after the installation is complete.
- Uninstall summary log may incorrectly show uninstall status as fail on non-English OS.
Chipset Support
| Windows 10 | Windows 11 |
AMD WRX80 | Yes | Yes |
AMD TRX40 | Yes | Yes |
AMD X670E / X670 | Yes | Yes |
AMD B650E / B650 | Yes | Yes |
AMD X570 | Yes | Yes |
AMD B550 | Yes | Yes |
AMD A520 | Yes | Yes |
AMD X399 | Yes | Yes |
AMD X470 | Yes | Yes |
AMD B450 | Yes | Yes |
AMD X370 | Yes | Yes |
AMD B350 | Yes | Yes |
AMD A320 | Yes | Yes |
Processor Support
AMD Ryzen™ Threadripper™ PRO Processors | Yes | Yes |
AMD Ryzen™ 7000 Series Desktop Processors | Yes | Yes |
AMD Ryzen™ 5000 Series Desktop Processors | Yes | Yes |
2nd/3rd Gen AMD Ryzen™ Threadripper™ Processors | Yes | Yes |
1st Gen AMD Ryzen™ Threadripper™ Processors | Yes | No |
2nd/3rd Gen AMD Ryzen™ Desktop Processors | Yes | Yes |
1st Gen AMD Ryzen™ Desktop Processors | Yes | No |
AMD Ryzen™ 3000G/4000G/5000G Series Desktop Processors with Radeon™ Graphics | Yes | Yes |
AMD Ryzen™ 2000G Series Desktop Processors with Radeon™ Graphics | Yes | No |
AMD Ryzen™ Mobile 3000U/C, 4000U/H, 5000U/H/HS, 6000U/H/HS/HX Series Processors with Radeon™ Graphics | Yes | Yes |
AMD Ryzen™ Mobile 2000U Series Processors with Radeon™ Graphics | Yes | No |
7th Gen AMD A-Series Processors | Yes | No |
Package Contents
The AMD Ryzen™ Chipset Driver installation package contains various independent drivers designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD product.
Driver Name | Windows
10 | Windows
11 | Change Details |
AMD Ryzen Power Plan / AMD Processor Power Management Support | 8.0.0.13 | 8.0.0.13 | No change |
AMD PCI Device Driver | 1.0.0.90 | 1.0.0.90 | No change |
AMD I2C Driver | 1.2.0.121 | 1.2.0.121 | Bug fixes |
AMD UART Driver | 1.2.0.114 | 1.2.0.114 | No change |
AMD GPIO2 Driver | 2.2.0.130 | 2.2.0.130 | No change |
PT GPIO Driver | 3.0.0.0 | 3.0.0.0 | No change |
AMD PSP Driver | 5.24.0.0 | 5.24.0.0 | Bug fixes |
AMD IOV Driver | 1.2.0.52 | Not Applicable | No change |
AMD SMBUS Driver | 5.12.0.38 | 5.12.0.38 | No change |
AMD AS4 ACPI Driver | 1.2.0.46 | Not Applicable | No change |
AMD SFH I2C Driver | 1.0.0.86 | 1.0.0.86 | No change |
AMD USB Filter Driver | 2.1.11.304 | Not Applicable | No change |
AMD SFH Driver | 1.0.0.336 | 1.0.0.336 | Bug fixes |
AMD CIR Driver | 3.2.4.135 | Not Applicable | No change |
AMD MicroPEP Driver | 1.0.40.1 | 1.0.40.1 | No change |
AMD Wireless Button Driver | 1.0.0.2 | 1.0.0.2 | No change |
AMD PMF-6000 Series Driver | 22.0.3.0 | 22.0.3.0 | No change |
AMD PPM Provisioning File Driver | 8.0.0.20 | 8.0.0.20 | Bug fixes |
AMD USB4 CM Driver | 1.0.0.31 | Not Applicable | Bug fixes |
AMD AMS Mailbox Driver | 2.0.0.572 | 2.0.0.572 | No change |
AMD S0i3 Filter Driver | 1.0.0.16 | 1.0.0.16 | No change |
AMD 3D V-Cache Performance Optimizer Driver | 1.0.0.7 | 1.0.0.7 | No change |
AMD Ryzen™ Chipset Driver 5.05.16.529 installation package can be downloaded from the following link:
By clicking the Download button, you are confirming that you have read and agreed to be bound by the terms and conditions of the
End User License Agreement (“EULA”). If you do not agree to the terms and conditions of these licenses, you do not have a license to any of the AMD software provided by this download.
Installing AMD Ryzen Chipset Drivers
For detailed instructions on installing AMD Ryzen Chipset drivers, refer to the following article:
