PLEASE NOTE: THIS IS A LIVING DOCUMENT AND CHANGES VERY OFTEN. AS NEW ITEMS ARE FIXED THEY WILL BE ADDED.
ETA to Experimental: Within next 2 hours
ETA to Stable: No current ETA, dependent on testing results
Known Issues:
Physics: Item throwing physics is currently disabled
Melee: Gestures currently do not work from two-handed melee
Melee: Cannot conduct melee attack from "lowered" melee stance (press space to chance stance to "raised")
New:
Actions: Vomiting have associated sound effects
Actions: Ballistic helmet variants can be painted to black and green color with spraycan
Actions: Can check pulse on unconscious players
Actions: Searching for berries will now add berries to your inventory
Actions: Eat All now supported for consumables
Actions: You can catch rain into canteen and water-bottle from inventory
Animations: New Ruger 10/22 reload animations
Animations: Player now can sit with gun/weapon
Animations: Completely new two-handed melee animations. New right-handed poses, moves and attacks for axes, baseball bat, pipewrench, crowbar, fire extinguisher, shovel, farming hoe. "Low" and "Aim" stances introduced for stand, crouch and prone.
Environment: New rock textures
Food: Sambucus berry item added
Food: Canina berry item added
Gear: added black and UN ballistic helmet variants
Gear: can opener can be used as melee weapon
Gear: hard headgear (ballistic, moto, construction and pilot helmets) cannot be wear together with masks
Gear: Farming hoe configured and spawns
Gear: M4 attachment green variants added
Graphics: Adding lights to currently rendered scene changed
Graphics: Lighting from objects now is rendered during daytime also
Graphics: HDR improved and tweaked slightly to perform better with bright lights in scene (i.e. flashlights etc...)
Graphics: Engine supported point source light objects (e.g. Gaslamp) now working correctly
Map: Olsha has been updated
Map: Khelm has been updated
Map: New rock formations outside Svetlo have been created
Map: New Orthodox Chapel has been created
Map: Police Stations & Medical Centers have been placed across the map
Map: New villages surrounding Svetlo
Medical: Players can have a heart attack (declared as "irregular pulse" with pulse checking actions)
Weather: Rain, Clouds, Wind, calculated on server and distributed to clients
Weather: Rain now causes items and player to become wet
Zombies: Simple respawn mechanic implemented for zombies, pending more robust method
Fixed:
Actions: Added 'inUseItem' back to action on target function
Actions: Proper nutritional value will be added when eating near empty food
Actions: Berry picking script messages to player improved.
Actions: Crafting splint from bandages now uses whole disposable bandage and half of dressing bandage
Actions: Ruined rags/bandages and wooden sticks doesn't produce infinite splints
Actions: Clicking on Eat All action if amount of food is below 1/4 will result in playing only short eating animation
Actions: Edited player messages in force drink action and fixing broken limbs
Actions: Force feed/drink doesn't use whole quantity of some food/drink items also canteen is not destroyed after action
Animations: Bandage and eating pills animation glitch fixed.
Gear: Added color variants of ballistic helmets into loot spawns
Gear: Even lower chance of backpacks spawning on construction sites
Graphics: SSAO in options saved
Graphics: Rain effect settings changed
Graphics: Rain geometry optimized (28 bytes vs 12 bytes per vertex)
Graphics: Spot light culling fixed
Graphics: Fix of terrain intersections
Graphics: Fix of geometry trace for flares
Graphics: Rain now does not fall inside buildings for those on Lower/Disabled shadow settings
Login: Failure during new character creation could cause player to get stuck as unconscious
Map: Optimizations for Svetlo performance
Map: Forests surrounding Svetlo bugfixes
Medical: Would never actually die from zero health or blood due to medical conditions
Medical: Epi-pens will now wake anyone (briefly) from unconsciousness even if blood very low
Medical: Defibrillator used for restarting the heart of players who have a heart attack
Medical: Unconsciousness had irregular and unpredictable behavior (epi-pens will now always wake an unconscious player, unless they are having a heart attack)
Medical: Melee damage application system changed to better balance
Medical: Chance of bleeding from fists reduced significantly
Medical: Disconnected players avatars did not take shock or blood damage
Medical: Falling from height while sprinting did not kill player when it should have
Medical: Player could vault with broken legs
Network: Dropped items appeared only after a delay (now instant)
Network: Inventory items causing desync due to non-guaranteed update spam (hotfix currently until guaranteed message change is complete)
Network: Optimizations to network messaging updates should result in reduced bandwidth and some increases in FPS for clients/server
Structures: Changed inheritance of barrier structures (due to errors in logs)
Weapons: Long-range scope reticle properly centered
Zombies: Zombies aims mostly for chest area now when attacking (stops the "helmet of armor" change)
