General Graphics Issues
Drivers:
As of December 6th, the best drivers to use with GTAIV:
- nVidia: 180.48
- ATi: 8.11
ATi have also released the 8.12's RC3. This is a *BETA* driver, so
use at your own risk. There are reports that these drivers significantly increase performance in GTAIV.
Click here to download.
Credit:
FidelZastro
nVidia have also released the 180.84's for high end cards (8 - 9 - GTX2x series). This is a *BETA* driver, so
Windows XP 32bit
Windows XP 64bit
Windows Vista 32bit
Windows Vista 64bit
DirectX:
Ensure your update your DirectX!
Note: These links will take you to the web installer. A 300KB program which downloads the latest DirectX release from Microsoft.
Official download link.
Secondary link (skip annoying genuine checks)
Clip Capture
This feature records the last ~30 seconds of gameplay, as you run around in GTAIV, and has been attributed to a lot of different loading and FPS issues. Go into your options menu, move to the "Game" tab, then disable "Clip Capture".
Error Code RMN40
Cause: Windows XP SP3 required.
Solution:
Please click here.
Instructions: Simply download and install.
Warning: The download is over 300MB and the installation can take up to an hour. Be careful!
This issue can also occur in Vista if you are running Steam in XP compatibility mode.
Error Code RMN40 (Windows Vista)
Cause: Rockstar.
Solution: Set GTAIV to Windows 2K compatibility mode.
Instructions:
1. Locate the GTAIV directory.
X:\Steam\steamapps\common\grand theft auto iv\GTAIV
2. Right click "LaunchGTAIV.exe"
3. Select "properties"
4. Select the "compatibility" tab
5. Tick "Run this program in compatibility mode for:"
6. Select "Windows 2000"
7. press "OK"
8. Run the game from the "LaunchGTAIV" exe
Error Code MMA10
Cause: Rockstar Social Club
Note: Also try the "Social Club Fatal Error" solution (below).
Solution: Simply log out of the Social Club before playing GTAIV. To sign out, click the "Log Out" button below your username int he Social Club window:
Notes: If you wish to play multiplayer, simply minimize GTAIV, log into the the Social Club, then maximize GTAIV once more. Multiplayer will work just fine.
Error Code RMN20
Cause: Windows Vista SP1 required.
Solution:
Windows Vista 32bit SP1
Windows Vista 64bit SP1
Instructions: Simply download and install the correct version (either 32bit or 64bit)
Warning: The downloads are over 400MB and the installation can take up to an hour or more. Be careful!
Black / Missing Textures
Cause: Corrupt graphics drivers.
Solution:
Please click here.
Alternate solution:
Please click here.
Notes: Some users have reported that reducing their game resolution fixed the "no texture" issue.
Games for Windows Live Issues
Cause: -
Solution: Update your GFWL redist.
Instructions:
1)
Click here
2) Click "Download the Latest Update"
3) Install
Graphics Restrictions
Cause: Rockstar attempting to protect us from ourselves.
Solution:
Please click here.
Buggy Sound / White Noise
Cause: Old sound card drivers.
Notes: Only seems to affect Realtek Onboard Audio.
Solution:
1.
Click here
2. Download and update
"Router Too Strict / NAT"
Cause: Firewall.
Solution: Add GTA to your Firewall exclusions list (Win XP/ Win Vista), and forward the following ports:
TCP/UDP 88
TCP/UDP 3074
If you don't know how to forward ports with your modem/router, see here:
http://www.portforward.com/english/r...outerindex.htm
Find your modem/router, then locate "XBOX LIVE 360" in the next menu.
Cause: Outdated .NET Framework.
Credit:
dawnclover
Solution: Install .NET Framework v3.5 w/ Service Pack 1.
.NET Framework v3.5
.NET Framework v3.5 SP1
This Game is Currently Unavailable...
Cause: Obselete version of Visual C++.
Solution: Download either the
32bit Version, or the
64bit Version of Visual C++ redist.
Notes: If that fails to help,
please click here. And if you don't know what Windows version you have, head on over to Control Panel, then System. Look for either "32 bit" or "64 bit" in your operating system information.
GFWL Asking For CDKEY
Cause: Registry bug.
Solution:
BE VERY CAREFUL IN YOUR REGISTRY
1) Click Start
2) Click Run / Vista users simply need to type into the "Search" box
3) Type: regedit
4) Expand HKEY_CURRENT_USER
5) Scroll down and locate "SOFTWARE" then expand it
6) Scroll down and locate "Rockstar Games" then expand it
7) Click on "Grand Theft Auto IV"
8) Locate your key in the right quadrant
Error At Main Menu
Cause: Outdated Adobe Flash.
Reported By:
nsscandyman
First uninstall Adobe Flash with this program
Solution: Download and install both of the following:
Adobe Flash Download #1
Adobe Flash Download #2
"The Application Has Failed To Launch"
Cause: Bug when downloading GTAIV through Steam.
Credit:
SmileSkill
Solution:
1) Manually navigate to the Steam folder
2) Open "SteamApps"
3) Open "Common"
4) Open "Grand Theft Auto IV"
5) Open the "RGSC" folder
6) Double click "RGSCLauncher"
7) Click back
8) Open "GTAIV"
9) Double click "LaunchGTAIV.exe"
After completing these steps, GTAIV should launch successfully whether you open through Steam or "LaunchGTAIV.exe"
Game Pad Not Working
Cause: Rockstar.
Notes: Rockstar is currently working on adding support for a larger variety of game pads. Here is the current list of supported game pads:
- XBOX 360 for Windows (Controller)
- Wireless XBOX 360 Controller
- Joytech 360 pad (Controller)
- Pelican TSZ360 Pad (Controller)
- MadCatz 360 (Controller)
- MadCatz 360 Pro (Controller)
- MadCatz 360 MicroCon (Controller)
- Bigben Controller BB7201 (Controller)
- MadCatz Arcade GameStick 360
- Logitech Chillstream
However there is also another way to "emulate" the XBOX360 controller using the following method:
1)
2) Navigate to your SYSTEM32 directory (C:\Windows\System32)
3) BACK UP THE FOLLOWING FILES
- xinput1_3.dll
- xinput1_2.dll
- xinput1_1.dll
- xinput9_1_0.dll
3) Extract the contents of the archive to your SYSTEM32 directory (C:\Windows\System32)
4) Start playing GTAIV with your controller
SecuROM Launcher Has Stopped Working
Cause: You are running the D3DOverrider application that comes with RivaTuner.
Solution: Disable/Uninstall the D3DOverrider application.
Lack of Motion Blur
Cause: The depth of field / motion blur filter is disabled by default.
Solution: Press the "P" button on your keyboard while in game to enable and disable the filter.
