sei que a pergunta é estupida mas estou encucado...
sempre li por ai que os ps3 slim eram 110. hoje chegou o que comprei no soubarato (sem isopor de proteção, veio batendo solto dentro da caixa) e na parte de baixo do console e no manual diz que ele é bivolt. não seriam só os super slim bivolt?
cara, quase todos são
"All the PS3 models (except early FAT, see table below) have a built in universal power supply, and supports multivoltage. What this means is that even though a specific voltage is written on the outside of the PS3, the PS3 can actually be plugged into any voltage anywhere in the world and work (as long as you have the correct cable). Therefore, if you opened up the PS3, the supported voltages should be stated (on the power supply) as 100V-240V, which is the range for all power outlets in the world. "
http://www.ps3devwiki.com/wiki/Power_Supply
