Saiu O R300
DekerBSB
Registered User
SAIU SAIU SAIU!!!!!!!!
EEEEEEIIIIIIAAAAAAAAA
xo ler as review aqui pra ver se é rox.....
DekerBSB
Registered User
Vamos começar com a humilhação......
THG:
There's no denying the fact that the specifications of Radeon 9700 promise a very fast graphics card. While full blown test samples are unfortunately still a few weeks away, we were given the chance to test a prototype and compare its performance to a GeForce4 Ti4600 in an identical system.
Tests showed that Radeon 9700 is clearly superior to NVIDIA's GeForce4 Ti4600, especially once high resolutions, FSAA or anisotropic filtering are used.
Thanks to the superior performance of Radeon 9700 under FSAA and anisotropic filtering, there is hardly any reason left to run games without these features, as the performance penalty is considerably small. ATi's new high-end card beats GeForce4 Ti4600 even in terms of quality
Here are a few numbers for those of you who can't wait. The 3DMark2001SE score of GeForce4 Ti4600 was 11,400, while Radeon 9700 with its young driver scored 14,000. Once 4x FSAA and 8x anisotropic filtering was used, the scores changed quite significantly. GeForce4 Ti4600 was able to get a mere 4500 points, while Radeon 9700 scored 10,000 points and thus more than twice the points of the competitor from NVIDIA.
DekerBSB
Registered User
e agora pelo site Anandtech
UT2003: Using the most stressful DM map, R300 is able to outperform a Ti4600 by 38-54% across several different resolutions!
UT2003: Under 4x Antialiasing situations, R300 is a whopping 251% and 228% higher than a Ti4600 under various settings!
As Anand pointed out, just when you thought Quake3 framerates couldn't get any higher, R300 is capable of delivering 37% more performance than a Ti4600 @ 16x12!
ESSA PLACA É UM MONSTRO!!!
DekerBSB
Registered User
ROX.......
a placa comanda muito.....
    35.1 KB · Visitas: 267
caldas
Kenai
R300
Nao acredito que o efeito Matrox vai acontecer com a ATi nao ....
DekerBSB
Registered User
cara.a placa é um monstro...
eu achava que nem ia ser isso tudo......
to de cara mesmo......
Douglaster
A BESTA FERA >=D
Vou ter uma ereção ! Ja vendi meu rim esquerdo pra comprar 1 :p
camubembo
Follow Me
Here are a few numbers for those of you who can't wait. The 3DMark2001SE score of GeForce4 Ti4600 was 11,400, while Radeon 9700, with its young driver, scored 14,000. Once 4x FSAA and 8x anisotropic filtering was used, the scores changed quite significantly. GeForce4 Ti4600 was able to get a mere 4500 points, while Radeon 9700 scored 10,000 points, thus, more than twice the points of the competitor from NVIDIA. :D :D :D :D :D
kero ve o preco hihih!
camubembo
Follow Me
olha a cara de menino maroto do deker!
DekerBSB
Registered User
cara.....sem noção.....
vai da pra jogar UT2003 em 1024x768 com FIltro anisotropico e FSAA de boa.....
acho q ela chega nos brasil por uns 900-1000 reais nos primeiros meses....
Douglaster
A BESTA FERA >=D
KRALHOOO
Ja vendi meu rim por 15mil D$ no Santa helena ali
Tiraram na hora e ainda me deram um suquinho !!
Ja encomendei a minha :rolleyes:
DekerBSB
Registered User
haeiuheaiheaiuaeh
marota essa plaquinah que eu sei.....
camubembo
Follow Me
axo ke chega mais cara!
camubembo
Follow Me
pena ke nao posso esperar mais com minha RIVA TNT2!
Diablo
Since 2001
deker eu andei vendo... tá animal essa placa :)
Diablo
Since 2001
ut2003 r0x... mais r0x ainda com uma placa que fais isso :)
    43 bytes · Visitas: 243
DekerBSB
Registered User
essa placa é um canhão....reparem no DETALHE dessa mensagem
UT2003 - 1600x1200x32; 4XAA; 16XAF – The Radeon 9700 doused the Ti4600 by about 25%. Now get a load of this, that is with the GF4 running without AA or AF. With 4XAA turned on the Ti4600 was crushed by nearly 300%. The Radeon 9700 simply made quick work of the Ti4600 under this UT2003 demo.
Diablo
Since 2001
mal ai
em ordem...
1024x
1280x
1600x
    14.7 KB · Visitas: 243
lembrando q ela ainda VAI ser lancada enquanto a ti4600 jah esta a 4 meses no mercado..... NV30 com certeza vai esmagar..... humilhar....
DekerBSB
Registered User
e lembrando que esse modelo testado ainda nao e a placa final.........e foi o primeiro driver ainda...
imagina com a placa final e com drivers novos....
essa placa é um bicho......
NV30 tem obrigação de ser melhor........
assim como o R400 VAI esmagar o NV30.....
e assim segue......
M
marceeloc
Guest
A minha gf3ti500 com FFSA em 4x e AA em 8x deu nada menos que 4420 no 3dmark 2001 SE
Ja a minha Ti4600 deu 6390. sniff sniff
M
marceeloc
Guest
Vou dizer mais isso é muito RLZ os preços vão ter que cair ueeeebbbaa:D
