Como está meus sinais? Estão bons? http://imageshack.us/a/img834/2378/fvn9.jpg
Mode: | G.DMT | |
Type: | Interleave | |
Line Coding: | Trellis On | |
Status: | No Defect | |
Link Power State: | L0 | |
Downstream | Upstream | |
SNR Margin (dB): | 22.8 | 27.0 |
Attenuation (dB): | 26.0 | 17.0 |
Output Power (dBm): | 12.3 | 19.7 |
Attainable Rate (Kbps): | 10752 | 1412 |
Rate (Kbps): | 5664 | 576 |
K (number of bytes in DMT frame): | 178 | 19 |
R (number of check bytes in RS code word): | 16 | 12 |
S (RS code word size in DMT frame): | 1 | 4 |
D (interleaver depth): | 32 | 4 |
Delay (msec): | 8 | 4 |
Super Frames: | 1376410 | 1376453 |
Super Frame Errors: | 30 | 0 |
RS Words: | 93595910 | 23397695 |
RS Correctable Errors: | 3348 | 0 |
RS Uncorrectable Errors: | 284 | N/A |
HEC Errors: | 28 | 0 |
OCD Errors: | 0 | 0 |
LCD Errors: | 0 | 0 |
Total Cells: | 312575095 | 0 |
Data Cells: | 251774858 | 0 |
Bit Errors: | 0 | 0 |
Total ES: | 34 | 137 |
Total SES: | 1 | 58 |
Total UAS: | 47 | 1792199 |
A minha linha suporta até quanto?
Mode: G.DMT Type: Interleave Line Coding: Trellis On Status: No Defect Link Power State: L0 Downstream Upstream SNR Margin (dB): 22.8 27.0 Attenuation (dB): 26.0 17.0 Output Power (dBm): 12.3 19.7 Attainable Rate (Kbps): 10752 1412 Rate (Kbps): 5664 576 K (number of bytes in DMT frame): 178 19 R (number of check bytes in RS code word): 16 12 S (RS code word size in DMT frame): 1 4 D (interleaver depth): 32 4 Delay (msec): 8 4 Super Frames: 1376410 1376453 Super Frame Errors: 30 0 RS Words: 93595910 23397695 RS Correctable Errors: 3348 0 RS Uncorrectable Errors: 284 N/A HEC Errors: 28 0 OCD Errors: 0 0 LCD Errors: 0 0 Total Cells: 312575095 0 Data Cells: 251774858 0 Bit Errors: 0 0 Total ES: 34 137 Total SES: 1 58 Total UAS: 47 1792199
15Mbps fácil fácil..... Na verdade iria até 20Mbps ai moleza também.
Errado, se ele não estiver em uma porta ADSL2+ não chega 15 Mb não, 26 de att , 22 de SNR se jogar +5 MB e a porta for ADSL SNR vai fica menos de 15, e a oi não qualifica 14- de SNR em ADSL1 só de for ADSL2+, sem falar que ele não ta tão perto da DSLAN dele.
Ja corrigi meu erro, é porque na hora que eu vi, eu olhei pro "rate 10Mbps" achei que ele jatinha 10Mbps com 22 de SNR mesmo com 26 de ATN subiria 15Mbps e até mais um pouco, mas depois que vi que ele tem 5Mbps, ta sincronizado em ADSl1, mas o maxrate é parecido com o meu, da 10Mbps ai fácil, 15Mbps só vendo como fica os parametros em ADSL2+.
Sim, entendi, mas acho dificil, pois tem tecnico que segue o padrão rigoroso da Oi, Só autentica a linha com 14- de SNR se você estiver em ADSL+2, ou se tua atenuação for muito baixa, e a dele não é tão baixa, 26...
Um exemplo:
http://i.imgur.com/ybNMLV7.jpg
Sim, mas na Oi os cara qualificam por ATN.
Modulação: | G.992.1 Annex A |
Largura de banda (ativa/inativa) [kbps/kbps]: | 576 / 2.272 |
Dados transferidos (enviados/recebidos) [KB/GB]: | 0,00 / 2,47 |
Alimentação de saída (ativa/inativa) [dBm]: | 12,0 / 18,5 |
Atenuação de linha (ativa/inativa) [dB]: | 31,5 / 52,0 |
Margem SN (ativa/inativa) [dB]: | 17,0 / 22,0 |
Lol aqui eles qualificam por ATN, o SNR ta explodindo aqui, mas por causa da ATN que já não sei se é 35 ou 28 os cara só deixam os 5Mbps.
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (1 dB): 21.4 20.0
Attenuation (1 dB): 35.5 19.0
Output Power (1 dBm): 19.8 11.9
Attainable Rate (Kbps): 10528 1088
Path 0
Downstream Upstream
Mode: | ADSL2+ | |
SNR Margin (dB): | 8.3 | 27.8 |
Attenuation (dB): | 28.5 | 17.2 |
Output Power (dBm): | 12.6 | 19.6 |
Attainable Rate (Kbps): | 13644 | 1242 |
Rate (Kbps): | 5656 | 575 |
MSGc (number of bytes in overhead channel message): | 104 | 11 |
B (number of bytes in Mux Data Frame): | 12 | 8 |
M (number of Mux Data Frames in FEC Data Frame): | 1 | 16 |
T (Mux Data Frames over sync bytes): | 8 | 8 |
R (number of check bytes in FEC Data Frame): | 16 | 16 |
S (ratio of FEC over PMD Data Frame length): | 0.0728 | 7.9012 |
L (number of bits in PMD Data Frame): | 3185 | 162 |
D (interleaver depth): | 384 | 2 |
Delay (msec): | 6 | 3 |
Super Frames: | 0 | 442 |
Super Frame Errors: | 0 | 0 |
RS Words: | 0 | 3579 |
RS Correctable Errors: | 0 | 0 |
RS Uncorrectable Errors: | 0 | N/A |
HEC Errors: | 0 | 0 |
Total Cells: | 107950 | 3066437118 |
Data Cells: | 3731 | 2154224233 |
Bit Errors: | 0 | 65639 |
Total ES: | 38 | 137 |
Total UAS: | 68 | 1792251 |
Adsl2+
Mode: ADSL2+ Line Coding: Trellis On Status: No Defect Link Power State: L0 Downstream Upstream SNR Margin (dB): 8.3 27.8 Attenuation (dB): 28.5 17.2 Output Power (dBm): 12.6 19.6 Attainable Rate (Kbps): 13644 1242 Rate (Kbps): 5656 575 MSGc (number of bytes in overhead channel message): 104 11 B (number of bytes in Mux Data Frame): 12 8 M (number of Mux Data Frames in FEC Data Frame): 1 16 T (Mux Data Frames over sync bytes): 8 8 R (number of check bytes in FEC Data Frame): 16 16 S (ratio of FEC over PMD Data Frame length): 0.0728 7.9012 L (number of bits in PMD Data Frame): 3185 162 D (interleaver depth): 384 2 Delay (msec): 6 3 Super Frames: 0 442 Super Frame Errors: 0 0 RS Words: 0 3579 RS Correctable Errors: 0 0 RS Uncorrectable Errors: 0 N/A HEC Errors: 0 0 OCD Errors: 0 0 LCD Errors: 0 0 Total Cells: 107950 3066437118 Data Cells: 3731 2154224233 Bit Errors: 0 65639 Total ES: 38 137 Total SES: 1 58 Total UAS: 68 1792251
[/SPOILER]
Não consegui up para 10 mega nesse momento, mas embora esteja ruim o teu SNR a tua atenuação permite qualificação se você der uma conferida na tua fiação e encontrar algo que esteja derrubando o teu SNR talvez ainda aja chance de obter a qualificação para 10 mega.
Com o modem da oi fica com 11 o snr
A atenuação continua
Mas o modem da oi nao aceita o meu bridge.
Adsl2+
[/SPOILER]
Lembrando pessoal que nós temos um tópico apenas para averiguar os sinais:
http://adrenaline.uol.com.br/forum/...se-seu-sinal-de-internet-topico-dedicado.html
Status | Up |
Total Time | 4 hour 43 min 27 sec |
Modulation Type | ADSL_2plus |
Standard Used | G.992.5_Annex_A |
Standards Supported | G.992.1_Annex_A,T1.413i2,G.992.2,G.992.3_Annex_A,G.992.3_Annex_L,G.992.3_Annex_M,G.992.5_Annex_A,G.992.5_Annex_M |
Link Encapsulation Used | G.992.3_Annex_K_ATM, |
Link Encapsulation Supported | |
Link Encapsulation Requested | |
Line Encoding | DMT |
Data Path | L0 |
Interleave Depth | |
ATUR Vendor | 5245544b |
ATUR Country | 181 |
ATUC Vendor | 4946544e |
ATUC Country | 181 |
Current Rate(Kbps) | 11295 | 574 |
Max Rate(Kbps) | 21496 | 1288 |
Noise Margin(dB) | 18.9 | 27.2 |
Attenuation(dB) | 13.5 | 5.5 |
Output Power(dBm) | 11.5 | 8.5 |
Status Up Total Time 4 hour 43 min 27 sec Modulation Type ADSL_2plus Standard Used G.992.5_Annex_A Standards Supported G.992.1_Annex_A,T1.413i2,G.992.2,G.992.3_Annex_A,G.992.3_Annex_L,G.992.3_Annex_M,G.992.5_Annex_A,G.992.5_Annex_M Link Encapsulation Used G.992.3_Annex_K_ATM, Link Encapsulation Supported Link Encapsulation Requested Line Encoding DMT Data Path L0 Interleave Depth ATUR Vendor 5245544b ATUR Country 181 ATUC Vendor 4946544e ATUC Country 181
Downstream Upstream Current Rate(Kbps) 11295 574 Max Rate(Kbps) 21496 1288 Noise Margin(dB) 18.9 27.2 Attenuation(dB) 13.5 5.5 Output Power(dBm) 11.5 8.5
fiz troca para 10mb e quero saber se minha linha ainda continua com bons status?![]()
Se fosse para outra operadora ele até conseguiria, mas a Oi não vai bota 10 MB pra ele q ATT dele quase 30 com SNR 8, se ele conseguir eu tiro meu chapéu, eu uso Oi a 8 anos, e sei como essa empresa eh uam filho da mãe, pra não falar coisa pior, tem gente que tem sinal melhor que o dele, e eles não qualificam. Suportar é uma coisa, qualificar é outra.
Vou postar uma SS logo a baixo, de uma linha de um amigo meu desqualificada para 15 MB, para que vejam que não estou falando bobagens xD :$
http://i.imgur.com/4xMnNhk.jpg
Agora a linha qualificada para 10 MB:
http://i.imgur.com/TPFuGeI.jpg
Faz uns 3 meses que a Oi vendeu, porém:
