Driver novo pro Halo Infinite, se alguem tiver com Radeon 6xxx, gamepass PC e não estiver minerando nela
RN-RAD-WIN-HALO-INFINITE-MP
Radeon™ Software Adrenalin for Halo Infinite™ Highlights
Support For
The Radeon Software Adrenalin installation package for Halo Infinite™ (Multiplayer mode) contains the following:
Update: this driver is newer then 21.11.2 (Driver Version 21.30.33.05) vs 21.11.? (Driver Version 21.40.03.01)
Support For
- Halo Infinite™
- Multiplayer mode
- During Marvel’s Guardians of the Galaxy™ gameplay, some users may experience driver timeouts on some AMD Graphics products such as Radeon™ RX 5500 XT Graphics. A temporary workaround is to disable the Radeon™ Anti-Lag feature in Radeon™ Software.
- Some users may experience elevated disk space consumption by the Multimedia Athena Dumps folder.
- Visual artifacts may be observed while playing Call of Duty®: Black Ops Cold War on some AMD Graphics products such as Radeon™ RX 6800M Graphics.
- While playing PlayerUnknown’s Battlegrounds™ with multiple displays connected in extended mode, Radeon™ Software may become unresponsive when the user is in the lobby and attempts to open Radeon Software on the secondary display via the context menu. A temporary workaround is to press the Alt + R keyboard shortcut if this happens.
- Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
- Radeon performance metrics and logging features may intermittently report extremely high and incorrect memory clock values.
- Radeon Software Adrenalin for Halo Infinite™ Driver Version 21.40.03.01 for Windows® 10 and Windows® 11 (Windows Driver Store Version 30.0.14003.1000).
Radeon Software Adrenalin 21.11.? Download & Discussion
RN-RAD-WIN-HALO-INFINITE-MP Radeon™ Software Adrenalin for Halo Infinite™ Highlights Support For Halo Infinite™ Multiplayer mode Known Issues...
forums.guru3d.com
JonasBeckman:
Looks like AMD revamped Wattman quite a bit with these, interface is a bit unstable but a few crashes later I could apply the settings.
AMD Crash Defender is also integrated a bit more with these, can't be removed as a separate component as before though components like Ryzen Master SDK, DVR (Overlay and recording.) and WVR (VR related.) can still be uninstalled as before with tweaking.
Not much else to say for now, fan interface in Wattman also looks a bit different and the XML is quite overhauled so much of that had to be set up again but other than Wattman itself being a tad prone to crash so far nothing too problematic.
~Been using the driver for all of half an hour or so though so yeah not much to say this early on either.
