Tava com o 511.79 e do nada as vezes a sair do jogo o pc perdia sinal de vídeo e depois reiniciava. Vou testar esse 512.79.
Amernime Zone Radeon Insight Driver 22.3.2 Released
Polaris/Vega/Navi with V5 Dependencies
Legacy GCN 1/2/3
Updated & Revamped NzSetup
NzSetup:
Fixed Windows Update policy bug keep displaying opted from Windows Settings
Fixed crossfire registry value and servicing stack settings
Fixed switchable menu tweaks
Fixed setup frozen in MediaFoundation steps
Added option to use 3 different choice during codec installer
Polaris/Vega/Navi
Mobile RDNA / W11 - Possibility to use RSR feature
Fixed H265 corruption
Legacy GCN 1/2/3
Fixed missing DXVA function
Fixed missing OpenCL function
CURRENT INSIGHT RELEASE MULTIPARSE FOR GCN
Adrenalin Dependencies V3.5
(AMD 22.3.2) AMD Game Profiling
(AMD 22.3.2) Dx9/Dx11/Dx12 Stub
(AMD 22.3.2) DirectX/OpenGL PowerXpress Switching API
(AMD 22.3.2) Vulkan Instance Version: 1.3.203
(AMD 22.3.2) OpenGL Next: 29.20.11000.14802
(AMD 22.3.2) AMD VCE
(AMD 22.3.2) DirectX Display Kernel
(WU 27.20.22016.2) Vulkan Driver 2.0.188
(WU 27.20.22016.2) AMD Universal Dx12 Binaries: 8.18.10.427
(WU 27.20.21034.37) Mantle API Over GRVK
(WU 27.20.21034.37) Mantle Extension Over GRVK
(WU 27.20.21034.37) AMD Codec Framework
(WU 27.20.21034.37) AMD Universal Dx9/Dx10/Dx11 Binaries
(WU 27.20.21034.37) OpenCL 2.0: 10.0.3240.6
(WU 27.20.21034.37) DirectX 11 Binaries: 8.17.10.1697
(WU 27.20.21034.37) DirectX 3D: 9.14.10.01494
(WU 27.20.15030.3002) Kernel Base: 8.1.1.1634
(AMD 21.3.2) Kernel for Online Benchmark Validate
Se você olhar no Fórum da Nvidia, tá lotado dessas relamações de brilho.@Carlos Irving, já removi o driver 512.15, não aguentei continuar usando ele. Por algum motivo, o brilho do monitor ficou diferente de quando utilizo o 472.12, e pesquisando parece ser algo referente as novas implementações feitas pela nvidia nos novos drivers, tipo o nvidia scaling image e etc, parece que isso tá mexendo no brilho.
Vi uma chuva de reclamações sobre essas novas implementações, causando n bugs, uma delas é o brilho, eu pelo menos odiei como ficou aqui, foi como se a tela estivesse toda embaçada. Removi usando o DDU, instalei o 472.12 setando a opção instalação limpa, para no caso ter ficado algum vestígio do driver anterior.
Pronto, monitor ficou como deveria, tudo lindo, brilho ok e tudo funcional, tá complicado usar os drivers mais novos, parece que ainda ficarei um bom tempo no 472.12, com ele é zero problemas.
A minha é uma rtx 2060, infelizmente não gostei desse driver mais novo, mexeu logo em algo que prejudica muito minha saúde, que é o brilho.Se você olhar no Fórum da Nvidia, tá lotado dessas relamações de brilho.
Tá foda mesmo esses drivers da série 512.XX ou 511.XX.
Provavelmente tem um novo driver perto por causa do lançamento da RTX 3090 Ti. Não sei qual sua VGA, mas melhor ficar com esses antigos se não for jogar nada atual.
Eu não tenho muito pra onde correr, minha placa só tem 3 ou 4 drivers lançados, fiquei com o menos pior, o 511.65
simPessoal, estava assistindo um vídeo do canal do candido n7 sobre o geforce experience e tenho uma dúvida. Sempre evitei instalar o gfe junto com o driver, pois algo que me incomodava nele era o fato de sempre fazer a atualização do driver por um mais atual sem meu consentimento, isso me deixava possesso.
Mas estou vendo que estou perdendo uma ferramenta nativa até interessante, pois ela faz algo que na maioria das vezes não faço ideia do que configurar: a melhor configuração para extrair o máximo de performance/gráficos dos jogos. Vi o vídeo do candido e gostei do que o gfe pode fazer sobre isso.
Mas minha dúvida principal é: tem como configurar o gfe para não atualizar sem meu consentimento o driver de vídeo?
Galera, estou com um problema e 2 jogos com a minha rx570, forza horizon 5 e GOW, ambos ficam 5 minutos aberto, e depois fecham, no GOW fala device chash, e no forza e a memoria nao pode ser written, que merda e essa?
Engraçado que e somente com esses 2, vou tentar instalar esse q4, pra ver se resolve.vc mantem driver atualizado sempre na ultima versão?
Aqui na 6700XT driver + recente já achei 1 jogo dx12 (hellblade remastered) que não consigo jogar por 30segundos que sai pro desktop. Rodo DDU pra desinstalar e instalo o Radeon Pro 2021 Q4 e o mesmo jogo roda normal. Deve ser varios jogos assim, nem testei muito esse ultimo drv
Sugiro dar uma pesquisada pros jogos que você quer jogar no youtube e quais drivers rodam melhor pra sua placa ou a RX580. É muita loteria esses drivers 2022 da AMD. Ano passado estava mais estavel
NVIDIA 512.59 WHQL
Fixed Issues in this Release:
- Event ID 14 error when logging into Windows if Digital Vibrance setting is adjusted [3544567]
- [RTX 3050] Driver may randomly timeout and recover while using Google Chrome [3567457]
- [MSI GT83VR 6RF/GT83VR 7RF/GT83 Titan 8RG] Internal notebook monitor displays black screen after driver update. External monitor works fine. [3508108]
- [Vulkan]: Derivative TouchDesigner may crash processing OpenColorIO work [3575777]
- [Vulkan]: Enscape may not render correctly [3562578]
- IntelliCAD may experience instability issues [3529698]
- [Siemens Teamcenter / Siemens Tecnomatix]: resolves rendering issues when using older versions of GLSL [3513350]
Open Issues:
- Sonic & All-Stars Racing Transformed may crash on courses where players drive through water. [3338967]
- [NVIDIA Ampere GPU]: With the GPU connected to an HDMI 2.1 audio/video receiver, audio may drop out when playing back Dolby Atmos. [3345965]
- Club 3D CAC-1085 dongle limited to maximum resolution of 4K at 60Hz. [3542678]
- [RTX 3080/RTX 3090] Unreal Engine 5 may randomly crash with DXGI ERROR DEVICE_REMOVED error message [3614246]
Lançaram tbm uma versao preview 22.5.1 ( mais nova que essa whql) que tem otimizações pra jogos DX11 na serie rx6000 segundo os release notes, tomara que essas otimizações se estendam oara as polaris etc tbm...
It looks like it's based on UWP driver (newer version):
Driver Version - 22.10.01.03-220505a-379221E-AMD-Software-Adrenalin-Edition
AMD Windows Driver Version - 30.0.21001.3006
Direct3D API Version - 12.2
Vulkan™ API Version - 1.3.206
OpenCL™ API Version - 2.0
OpenGL® API Version - 4.6
[B]Direct3D® Driver Version - 9.14.10.01521[/B]
Vulkan™ Driver Version - 2.0.220
OpenCL® Driver Version - 10.0.3417.0
OpenGL® Driver Version - 29.20.11000.14800
2D Driver Version - 8.1.1.1634
UI Version - 2022.0505.2111.1929
AMD Audio Driver Version - 10.0.1.23
[/QUOTE]
Aqui o driver instalou mais houve erros, esta funcionando, mas ele tem um BUG quando entra em modo de economia de energia, que ou a imagem fica preta, precisando desligar e ligar o computador, ou volta com a imagem como se não houvesse driver.AMD Radeon Graphics Drivers 22.5.2 Preview
Latest AMD Radeon Graphics Drivers 24.4.1 WHQL Download
Download the latest AMD Radeon drivers for best game performance, compatibility and to fix driver issues. Radeon Adrenalin comes with a completelywww.techpowerup.com
Galera quais os melhores drivers para placas da Serie RX 400? Eu tenho uma RX 480 aqui e até então estava sempre atualizando para o ultimo driver, mas daí vi um video falando q o 21.12.1 (pra quem usa win 11) era o melhor driver para essa seríe aí fiquei na duvida e resolvi instalar, só que de ontem pra hoje o driver começou a dar erro e do nada ele desinstalou sozinho do meu pc (????????????) ai tive q reiniciar e instalar de novo. Não sei se foi aleatório o que aconteceu ou se vai continuar ocorrendo... Diante disso, vocês sabem se esse realmente é o melhor driver pra essa série?
