Grand Theft Auto V - [TÓPICO PERFORMANCE]
Chico
Darktronik
Ta liso e leve como se pode observar neste vídeo
[video=youtube;OPshgGUxd6g]https://www.youtube.com/watch?v=OPshgGUxd6g[/video]
:coolface: :coolface: :coolface:
Video memory slider: shows you how much video memory is being used in MB.
Ignore suggested limits option: game detects your setup automatically, but you can push your system further if you like.
Options for screen type, aspect ratio and refresh rate.
DirectX Version Output monitor: 1-3
Anti-aliasing: FXAA, MSAA and Nvidia TXAA supported.
Pause game on focus loss.
Scaling bars for population density, population variety and distance scaling.
Texture quality: normal to very high.
Shader quality: normal to very high.
Shadow quality: normal to very high.
Reflection quality: normal to very high.
Reflection MSAA
Water quality: normal to very high.
Particles quality: normal to very high.
Grass quality: normal to very high.
Soft shadows options: softer, softest, AMD CHS, Nvidia PCSS
Post FX options: up to ultra.
Motion blur strength: scaling bar.
In-game depth of field effects: on/off.
Anisotropic filtering: up to x16 .
Ambient occlusion options.
Tesellation options.
Advanced graphics
Long shadows: on/off.
High resolution shadows: on/off.
High detail streaming while flying: on/off.
Extended distance scaling bar.
Extended shadow distance bar.
Vou ajeitando o tópico com benchs e etc.
Mais vídeos:
[video=youtube;ckkkgzKKpLg]https://www.youtube.com/watch?v=ckkkgzKKpLg[/video] [video=youtube;D_vi968KQng]https://www.youtube.com/watch?v=D39Vs2PFJws [video=youtube;D_vi968KQng]https://www.youtube.com/watch?v=D_vi968KQng[/video]
[/video] [video=youtube;k3cPMPUuPwU]https://www.youtube.com/watch?v=k3cPMPUuPwU[/video] [video=youtube;HUEYJS799dI]https://www.youtube.com/watch?v=HUEYJS799dI[/video]
Matéria da Guru3D sobre performance:
http://www.guru3d.com/articles-pages/gta-v-pc-graphics-performance-review,1.html
index.php
Arte: [citar][seko][/citar]
LeBaldi
Running fucking fast
Boa... com a config da assinatura estou rodando com a config abaixo... hoje irei testar mais algumas coisas... aki tem ficado na cada de 50 a 60 FPS
ExaByte
Enfim consegui um ajuste fino para a GTX 970 aqui.
To rodando em 1440p com DSR, somente com FXAA habilitado, VSync...
Algumas screens para mostrar como ficou praticamente sem serrilhado...
~Naga
Ex-Membro Honorário
Aqui com x6 1090t, 8gb e hd 7970 rodou na média dos 60 fps
Às vezes cai pra 30 na cidade.
Deixei o jogo como veio configurado, a maioria no "Muito Alto" e algumas coisas no "Alto"
Confesso que nem me incomodei em mexer nas configs, fui jogando e boas :haha:
*Não estou com o último Catalyst
Vulkkra
3570k aqui e uma R9-280x 3gb... FPS vária muito. Estou jogando com tudo no alto basicamente e tem locais que esta 60, tem locais que cai para 30~. Já vi chegar até a 25. :poker:
XxDarkshotxX
xxdarkshotxx
.Thiago
õ/
Sério que cai pra 39 fps com sli de gtx 980 no benchmark? :seferrou::nooo::lol2:
pvorkut
960 pior que a minha 680 :haha::haha:
Muito fail essa VGA.
Acho que vou comprar o jogo, ta bão mesmo ?
chucklodders
Acho que configurei mal meu GTA V pois fiquei com 30fps cravado (1920x1080).
O recomendado para ele deveria ser uma VGA de 4gb.
L...
Grande FDP.
AllahuAkbar
Salaam Aleikum
Aqui eu tenho duas opçoes:
1. Jogar com as texturas no Very High mas com Densidade/FoV mais baixos
ou
2. Jogar com as texturas no normal mas com Densidade/FoV no Máximo.
Eu prefiro a segunda opção, pois as texturas pouco me incomodam, prefiro uma cidade cheia de vida msm. E rodando liso, ta bom demais.
viniciusc1986
Poxa, aqui o jogo fica direto na tela do social club, faz o login na social, mas fica dizendo la Carregando, e fica assim direto. n entra no jogo. alguem pode ajudar?
Safra 2004
Faltou uma tela aqui que deletei sem querer, mas fueda-se. Densidades quase no máximo, só dei um toque para não deixar a barrinha cheia.
59 FPS com uma ou outra queda para 58 ou em alguns momentos que varia na casa dos 40, especialmente em uma área próxima ao porto. Mas nada que afete a diversão. Depois tento colocar algo a mais ou um over na CPU, mas quem deve estar 'barrando' o jogo é a VGA.
Pra mim, porém, está ótimo. Jogo antigo? Sim. Mas tem muitos, muitos efeitos. Depois vou até testar por curiosidade com o DX 10.1 ou 10.
Só não pega 60 FPS (não vai além de 59hz). :hmm:
i7 4770k sem over (3.9), R9 280X 3 GB, 16 GB Ram, SSD.
Hanrrison
Galera, da uma olhada ai, to jogando entre 33~40 fps nessas config..
algo que eu possa melhorar?
geiop
eu sou eu e daí???
praticamente mesma config de pc aqui...
só não tenho oc na vga hahaa :p
não consegui usar textura ALTA ... com alto ia pra 2300mb
YarosFarian
cota pula
para referencias.. fiz um breve bench junto ao after + HW pra descobrir o q rola no game..
Minha config:
I7 3770
760 PNY 2GB
8gb de RAM
HD 1TB 7200rpm
Coloquei tudo no MAXIMO, ou seja, Ultra..
menos em 3 opções:
1 - Texturas
normal.. Pq? minha VGA é de 2gb..
2 - MSAA
deixo desligado, não gosto do CxB
3 - TXAA
deixo desligado, não gosto do "blur"
ou seja, o resto está tudo no ULTRA (clouds em HD e etc tbm)
[obs: full HD]
Isso é uma config idela pra min.. fico entre 95% ~ 97% da VGA
Não passou em nenhum momento dos 40% da cpu (UHUM O_O)
e n passa de 7gb de RAM
Taxa de fps? entre 40 a 60
UNICO PROBLEMA:
Loadings.. bem demorados..
quem tem ssd, aconelho a instaalr nele, deve sentir uma melhora gratificante na velo...
Chico
Darktronik
Qm tem placa com 2gb vram nao tem como usar textura alto mesmo...só sacrificando variedade demográfica, mas mesmo assim, fica com fps lá embaixo... menos de 30fps.
E o mínimo para jogar liso é 40fps
infestado
Love Gun
Usei as suas configs, ja q meu pc eh mto parecido, e fiquei satisfeito com o resultado! como nao entendo picas de AA, eu achava q usar o MSAA ia melhorar o resultado por ser nvidia, mas do jeito seu ficou melhor. reparei q o msaa nos reflexos tb n deu impacto na performance, mas vou manter igual o seu, nao quero ficar na paranoia de baixar fps no meio do game
Chico
Darktronik
Eu só acho que eles deveriam melhorar o contorno dessas sombras. Tem opção pra isso e ainda não fica certo. Ficam com aquelas tradicionais falhas ou serrilhados.
O extremamente suave nao está se aplicando adequedamente. (ou as opções AMD/nVIDIA).
