No Rtings tem isso:
Update 01/25/2021: We've retested the monitor to further investigate the BGR sub-pixel layout's effect on text clarity. In most instances, text clarity is
minimally impacted and shouldn't be an issue for most people.
That said, the difference in text clarity between RGB and BGR
isn't very noticeable at native scaling unless you're actively looking for it, so it shouldn't be an issue for most people.
Update 02/12/21: We tested text clarity with a MacBook running on Big Sur. It appears that macOS doesn't use sub-pixel dimming in any of the apps we tested, which includes Safari, TextEdit, Notes, Finder, and Chrome.
This means that blurry text isn't caused by the BGR sub-pixel layout. We've added some photos below.
Então, parece não ser esse o problema... alguma outra sugestão?
PS: como faço pra postar uma print aqui ?!
