[TÓPICO OFICIAL] Horizon Zero Dawn: Remastered
  • Iniciador de Tópicos Iniciador de Tópicos Catos
Aqui eu não consigo mais forçar AF pelo driver. Quando entro nas opções da Nvidia e clico em gerenciar configurações 3d, clico na aba pra selecionar os .exe ele fecha o painel. To com esse bug faz um tempo e não consigo resolver.
Acho que de essencial só falta o AF pra quem tem AMD pra ficar jogável
Hi everyone,
Patch 1.05 for Horizon Zero Dawn on PC is now available to download on Steam! If your game does not update automatically, please restart your client.
This patch addresses additional crashes, as well as a couple of community-reported bugs such as Aloy’s hair not displaying correctly when playing with the game running above 30 FPS, controller rumble toggle and adds the option to display black side bars in cinematics when playing in ultrawide resolutions. We are continuing to investigate open issues and will update you when we have more news available.
You can find the Known Issues and full patch notes below; if your issue isn’t among them, you can still send us your reports here.
Thank you for your continued feedback, patience, and support!
–Guerrilla
Known Issues
  • Some players are experiencing an out of memory error during the game optimization process.
  • Some players are experiencing graphical settings issues, such as Anisotropic Filtering or HDR not working correctly.
  • Some players are experiencing performance issues on specific GPUs or hardware combinations.
  • We're aware of and continue to investigate issues that are not yet solved on both the player-compiled lists by u/EvilMonkeySlayer and u/Rampage572 – thank you!
Patch Notes
Crash Fixes
  • Fixed a crash in NetPresenceManager that some players experienced when entering the game or the benchmark from the main menu
  • Fixed a crash where the Steam SDK could crash on initialization when the game executable was started directly from installation folder rather than through Steam
  • Fixed a crash which would occur if the player pressed ‘Stop’ in Steam immediately after pressing ‘Play’
  • Fixed a startup crash when using Avast antivirus
  • Fixed a crash that could occur when VRAM was about to be oversubscribed
Graphical Improvements
  • Fixed an issue with Aloy’s hair not displaying correctly when the game is running above 30 FPS
  • Shader animations (e.g. hologram locks on doors, GAIA in cinematics, etc.) are no longer locked to 30 FPS, but running at unlocked framerate
  • Fixed an issue with flickering textures in main quest “A Gift from the Past”
  • Fixed an issue with flickering snow assets
  • Fixed an issue with flickering paintings in Song’s Edge
  • Fixed graphical corruption issues that only occurred on specific GPUs
  • Fixed an issue where the game would open in windowed mode instead of fullscreen when the player is using another window when booting the game
  • Fixed an issue where the game would not run in the correct resolution when switching from windowed to fullscreen
  • Added an option to turn off “blurry sidebars” in ultrawide resolutions and display black sidebars instead
Other Improvements
  • Allow players to still boot the game even if the version of windows used is detected to be too low to run the game at a stable condition
  • Added an option to turn off controller vibration/rumble
  • Fixed an issue in the storing of the ‘permission to track data’ attribute of the player profile (subsequently re-asking for said permission)
  • Fixed an issue where the opening cutscene music would not play if the player quits out and immediately begins a new game
  • Fixed an issue where inverting mouse controls also affected dialog tree choice input
Cabelos se movendo lindamente! :wub:
Jogo aqui agora tá perfeito! :banderas:
Estranho, aqui continua de boas o AF pelo driver. :confused:
Como eu forço o AF pelo painel nvidia? Tenho medo de mexer e bugar algo..
Abra o painel de controle da Nvidia - Gerenciar as configurações em 3D - Configurações do programa - selecione o jogo - coloque filtragem anisotrópica em 16x - salve
Depois de ativar o AF via painel NVIDIA vai precisar apagar o arquivo de shader dentro da pasta do jogo pro jogo refazer os shaders, se não vai bugar tudo.
Boa noite. Estou precisando de ajuda para rodar o jogo.
Não estou conseguindo jogar usando a placa de vídeo dedicada do notebook. (O jogo trava na tela de carregamento quando tento iniciar novo jogo).
Tenho um Acer Aspire 3 a315 42g r6fz (ryzen 5 3500u, radeon 540x e 8gb de ram). Sei que ele não atende os requisitos mínimos, mas ele com certeza deveria rodar o jogo.
O problema é que o jogo não funciona se eu uso a placa de vídeo dedicada (Radeon 540x, com 2gb).
Fiz os seguintes testes:
1º - Coloquei o jogo em modo de alto desempenho, para que usasse a placa de vídeo dedicada. Coloquei absolutamente tudo no mínimo, mas o jogo sempre trava na tela de carregamento e fecha.
2º - Coloquei em modo de economia de energia. Assim ele usou apenas a placa de vídeo integrada (Vega 8, com 2gb). Deixei na qualidade "priorizar desempenho", do jeito que o jogo sugeriu. O jogo carregou e rodou a 20 FPS.
Alguém sabe como resolver isso?
Certo, farei isso mas aí funfa o AF ?
É né, a ideia é que funfe se você fizer isso
O jogo já tá um pouco complicado de rodar para quem tem os requisitos recomendados, imagina abaixo :x
É esse jogo definitvamente ta entrando no meu Top 3 melhores jogos da minha vida pqp. Que historia fudida de boa e a Aloy sem comentários, que protagonista, fazia tempo que eu não jogava um jogo com uma protagonista tão boa. Ansioso demais pela minha placa de video nova chegar pra eu poder jogar isso a 60 fps estaveis
Dei uma rápida testada no patch novo (já zerei o game), os cabelos da Aloy realmente melhoraram em 60fps. Mas ainda não me parece estar 100%...
Eu voltei a jogar Skyrim socado de mod a 40 fps, mas ainda não comecei Horizon Zero Dawn por causa desse port :haha:
Olha, o enredo desse jogo é incrível..
Ontem a noite consegui deixar o vício do Satisfactory de lado e testei esse patch. Cara, que ganho ridículo de desempenho. E o mais interessante é que antes do patch, pra mim o cabelo da Aloy estava legal, mas agora nota-se ele muito mais. A animação dele é realmente muito bem feita.
Pelo menos aqui,a cada novo patch mais liso o jogo fica.
Era pra ter liberado o jogo desse jeito, no mínimo.
Deram as chaves de teste com acesso antecipado pra quê? Pra fazer publicidade de um jogo incompleto.
Olha o quanto o jogo sofreu até chegar ao que tá hoje. Tudo isso poderia ter sido evitado com beta testers.
Qual arquivo é? Talvez seja isso que ta bugando meu driver da Nvidia.
Pra min já está bem otimizado o game, minha config atual:
i5 9400f
16 gb ram
GTX 970
SSD
to rodando em média 50 fps com os parâmetros mesclado em High e Ultra, só as nuvens deixei no médio...
Concordo, mas com não veio, só nos resta isso. Pelo menos estão corrigindo o jogo. Estou olhando pra você, Nier Automata.
Ainda bem que não aconteceu o mesmo com o Horizon.
NiEr e Dark Souls, dois jogos que não foram corrigidos mas foram reembalados com todos os defeitos e revendidos como remaster/GotY Edition.
Muita cara de pau!
