Ja teve a 65xx no aligatorshop, eu ja apostaria nos 6 mil em breveTem umas 3 semanas nesse preço lá. Já já vai pra 6.5k
47IOM7MD7AEG | 47IOM7MD6TTS |
DESCRIÇÃO | ESPECIFICAÇÃO | DESCRIÇÃO | ESPECIFICAÇÃO |
| GPU Engine Specs:
| GPU Engine Specs:
A Ex gamer tem o clock levemente superior, na prática ambas são iguais. A Ex tem RGB no logo e a ST vem com aquele fan extra.Alguem sabe me informar qual a diferença entre este modelos 47IOM7MD6TTS e 47IOM7MD7AEG da galax ?
GALAX GeForce RTX™ 4070 Ti ST 1-Click OC
<div id="featurebullets_feature_div" class="feature" data-feature-name="featurebullets"> <div id="feature-bullets" class="a-section a-spacing-medium a-spacing-top-small"> <ul class="a-vertical a-spacing-none"> <li><b>NVIDIA Ada Lovelace Streaming Multiwww.galax.com
GALAX GeForce RTX™ 4070 Ti EX Gamer
47IOM7MD7AEG 47IOM7MD6TTS
DESCRIÇÃO ESPECIFICAÇÃO DESCRIÇÃO ESPECIFICAÇÃO
- NVIDIA Ada Lovelace Streaming Multiprocessors: Up to 2x performance and power efficiency
- 4th Generation Tensor Cores: Up to 2X AI performance
- 3rd Generation RT Cores: Up to 2X ray tracing performance
- Microsoft DirectX® 12 Ultimate
- GDDR6X Graphics Memory
- NVIDIA DLSS
- NVIDIA® GeForce Experience™
- NVIDIA G-SYNC®
- NVIDIA GPU Boost™
- Game Ready Drivers
- Vulkan RT API, OpenGL 4.6
- DisplayPort 1.4a, HDMI 2.1
- HDCP 2.3
- VR Ready
- To 1-Click OC, overclock, control ARGB and monitor GPU info of your graphics cards in-App, please make sure your mobile device and PC are connected with the same WiFi network.
- All photos, specifications, contents are used for reference only and are subject to change without notice. Actual products in different countries varies and are best to consult your local distributor / importer for confirmation.
GPU Engine Specs:
Memory Specs:
- CUDA Cores: 7680
- Boost Clock: 2670MHz
- 1-Click OC Clock: 2685MHz (by installing Xtreme Tuner Plus Software and using 1-Click OC)
Feature Support:
- Memory Speed: 21 Gbps
- Standard Memory Config: 12GB
- Memory Interface Width 192-bit GDDR6X
- Memory Bandwidth: 504 GB/sec
Fan Feature:
- PCI-E 4.0
- Windows 10/11 64-bit
Display Support:
- 2 * 92mm, 1 * 102mm
- WING 2.0 with Fan stop @ Idle (All Fan)
Dimensions:
- DisplayPort 1.4a x 3, HDMI 2.1 x 1
In Box Accessories:
- Dimensions(with Bracket): 336 * 146 * 62mm
- Dimensions(without Bracket): 323 * 131 * 60mm
- Aluminum GPU Support Stick
- PCIe 16-pin to 2x PCIe 8-pin adaptor
- 1-Click Sync Pro cable
- NVIDIA DLSS
- NVIDIA G-SYNC®
- NVIDIA GPU Boost™
- HDCP 2.3
- VR Ready
GPU Engine Specs:
Memory Specs:
- CUDA Cores: 7680
- Boost Clock: 2610MHz
- 1-Click OC Clock: 2625MHz (by installing Xtreme Tuner Plus Software and using 1-Click OC)
Feature Support:
Fan Feature:
- PCI-E 4.0
Display Support:
Dimensions:
In Box Accessories:
- Dimensions(with Bracket): 336 * 148 * 62mm
- Dimensions(without Bracket): 320 * 133 * 62mm
- 1-Clip Booster 2.0 Fan
Pelo que to vendo sao identicas, agora nao sei se a diferença sao consumo ou sei la oque.
PS: To enchendo o saco, pq to fechando a comprar desta placa e como sao caras acho que por mais besteira que seja a duvida, nao custa pelo menos perguntar.
Blz,,,A Ex gamer tem o clock levemente superior, na prática ambas são iguais. A Ex tem RGB no logo e a ST vem com aquele fan extra.
- NVIDIA DLSS
- NVIDIA G-SYNC®
- NVIDIA GPU Boost™
- HDCP 2.3
- VR Ready
GPU Engine Specs:
Memory Specs:
- CUDA Cores: 7680
Feature Support:
Fan Feature:
- PCI-E 4.0
Display Support:
Dimensions:
In Box Accessories:
- NVIDIA DLSS
- NVIDIA G-SYNC®
- NVIDIA GPU Boost™
- HDCP 2.3
- VR Ready
GPU Engine Specs:
Memory Specs:
- CUDA Cores: 7680
Feature Support:
Fan Feature:
- PCI-E 4.0
Display Support:
Dimensions:
In Box Accessories:
Um passarinho nos contou que a Intel está procurando por parceiros para produzir suas placas gráficas de próxima geração, claro que na China. Mas assim que eles recorreram a fabricantes conhecidos de primeira linha (ASUS, Gigabyte, ...), a NVIDIA começou a ameaçar seus parceiros de que, se eles colaborassem com a Intel, ela não trabalharia mais com eles e portanto não receberiam mais seus chips.
É preciso lembrar que isso já aconteceu com a AMD: Naquela época, a NVIDIA estipulava que suas placas de vídeo e placas de vídeo AMD não podiam ter a mesma marca, você tinha que nomeá-las de maneira diferente. Um alvoroço se seguiu e a ASUS, por exemplo, até já havia criado uma marca separada, mas a NVIDIA desistiu sob pressão pública. Então agora a história ficou ainda pior. Aparentemente, os OEMs de GPUs de primeira linha não assinarão um acordo com a Intel e a empresa já está procurando parceiros de segundo nível.
O público, se soubesse da situação, poderia envergonhar a NVIDIA novamente, mas desta vez a situação está se desenvolvendo à portas fechadas, no nível das relações de empresas, que fiquei sabendo acidentalmente graças a um funcionário de uma empresa que aparentemente assinará uma parceria com a Intel. É improvável que este parceiro da Intel se manifeste e revele a verdade publicamente.
- NVIDIA DLSS
- NVIDIA G-SYNC®
- NVIDIA GPU Boost™
- HDCP 2.3
- VR Ready
GPU Engine Specs:
Memory Specs:
- CUDA Cores: 7680
Feature Support:
Fan Feature:
- PCI-E 4.0
Display Support:
Dimensions:
In Box Accessories:
- NVIDIA DLSS
- NVIDIA G-SYNC®
- NVIDIA GPU Boost™
- HDCP 2.3
- VR Ready
GPU Engine Specs:
Memory Specs:
- CUDA Cores: 7680
Feature Support:
Fan Feature:
- PCI-E 4.0
Display Support:
Dimensions:
In Box Accessories:
Não entendi, porque a ex-gamer tem um clock maior.
Mas não seria a EX modelo de entrada e a ST/SG intermediario?
Pelas fotos, a ST é bem mais robusta. Alguém poderia confirmar?
Pouquíssimos parceiros da NVIDIA estão interessados em lançar a GeForce RTX 4060 Ti de 16GB
Very few NVIDIA board partners interested in promoting GeForce RTX 4060 Ti with 16GB memory - VideoCardz.com
NVIDIA RTX 4060 Ti is getting twice the memory soon According to Andreas Schilling (HardwareLuxx), NVIDIA board partners seem uninterested in the upcoming launch of another RTX 4060 Ti graphics card. NVIDIA announced that it will be providing two memory configurations for its latest desktop...videocardz.com
"Dado o número limitado de modelos anunciados para a nova configuração da versão Ti, Andreas Schilling (do HardwareLuxx) decidiu entrar em contato com vários AIBs para obter informações sobre o assunto. A resposta deles não surpreendeu: a falta de atratividade decorre do alto preço desse modelo.
A GeForce RTX 4060 Ti com 16GB de memória só terá um propósito: Acalmar aqueles críticos que acham que 8GB não são suficientes (vou contar um segredinho: é exatamente isso!). Mas esse modelo mais bem equipado não é muito atrativo em termos de preço e posicionamento. -- Andreas, via Twitter"
NVIDIA ameaça banir parceiros que decidirem lançar GPUs da Intel, afirma canal Russo PRO High-Tech
NVIDIA unhappy board partners may work with Intel on the Battlemage Series - VideoCardz.com
Rumor claims NVIDIA does not want to see more Intel GPUs from its partners Russian channel PRO Hi-Tech reports that NVIDIA is pressuring the largest partners to refuse working with Intel on the next-gen GPU launch. The report goes into saying that NVIDIA would go as far as ban such partners if...videocardz.com
"O relatório diz que a NVIDIA iria tão longe quanto proibir tais parceiros se eles decidissem lançar GPUs baseadas na série Intel. Diz-se que as limitações de fornecimento de GPU podem ser aplicadas se eles decidirem seguir seus planos. Isso já está acontecendo na China, onde essas empresas estão se preparando para o lançamento da nova série Intel. Infelizmente, o relatório não tem nenhuma evidência, e é extremamente difícil confirmar tal informação. No entanto, PRO Hi-Tech é um canal bem conhecido que tem fortes conexões com muitas empresas, então não há dúvida de que algo está em jogo aqui. Além disso, esta não seria a primeira vez que a NVIDIA é acusada de algo do tipo (basta lembrar-se do GPP - GeForce Partner Program)."
Na verdade esse seria o boicote ideal, TODOS aderissem à Intel para baixar a bola da verdinha, pois duvido que ela 'baniria' todo mundo, e se ela chutasse uns e outros não, ficaria claro publicamente que ela favoreceu uns e outros não, possivelmente tendo que voltar atrás... mas duvidaria que empresas como a GALAX fosse para Intel, algumas preferem morrer que ir para outra brand. Claro que não tem como provar nada, mas vindo da NVIDIA não duvido nem um pouco xDJogo sujo demais da NVIDIA (se essa informação, for verdadeira).
Seria top, todos lançarem o modelo da intel, ai baniria todos kkkkkkk
Duvido nada a Nvidia querer forçar a mão dos parceiros pra no final ela só vender diretamente os produtos e aumentar as margens.Na verdade esse seria o boicote ideal, TODOS aderissem à Intel para baixar a bola da verdinha, pois duvido que ela 'baniria' todo mundo, e se ela chutasse uns e outros não, ficaria claro publicamente que ela favoreceu uns e outros não, possivelmente tendo que voltar atrás... mas duvidaria que empresas como a GALAX fosse para Intel, algumas preferem morrer que ir para outra brand. Claro que não tem como provar nada, mas vindo da NVIDIA não duvido nem um pouco xD
* coceira no brioco consumistaBom, em breve, vou estar na família 4000 também.
Encomendei hoje na Patoloco, junto com um gabinete Lancool 216, uma 4070 MSI Gaming X Trio. Sei que em termos de performance, passar da 3080 10G pra ela é meio que trocar 6 por meia dúzia, mas, tive alguns motivos:
* reduzir a perda de dinheiro com a troca da 3080, porque na geração 5000 ela vai estar ainda mais desvalorizada
* menores consumo, temperaturas e ruído (motivo principal)
* DLSS3
Vi vários reviews que mostram que esse modelo da MSI é excelente nos motivos principais, e que com um leve OC, ela reduz as eventuais perdas em relação a 3080 10G. Deve tá chegando até o fim do mês, porque vem de FedEx até aqui onde moro no NE.
Comprei essa da Msi,paguei um pouco mais,boa placa.fria e silenciosa.Tem umas 3 semanas nesse preço lá. Já já vai pra 6.5k
Lembrei desse post que eu fiz quando a EX apareceu e acabou deixando a galera um pouco confusa.
Resumo:
- EX e SG tem clocks de fábrica ligeiramente superiores ao da ST (2670 vs 2610Mhz);
- EX é ligeiramente menor que SG e ST;
- ST é o modelo pé de boi, sem leds, rgb e afins, mas com o mesmo sistema de refrigeração das demais (2x 92mm + 1x 102mm).
Na prática todas devem atingir o mesmo clock de boost e temperaturas, variações se houverem irão depender mais do ambiente e ventilação do gabinete do que das placas em si.
Se tiver em dúvida sobre qual escolher pegue a mais barata (SG ou EX se quiser leds).
Nunca vi relato do problema nas 4070...Galera, estou monitorando a 4070, estava de olho nas promoções da Msi X trio, justamente por poder sincronizar com minha mobo, também msi, além de ser um projeto robusto e preço interessante em promoções. Mas o que me deixa pé atrás é o conector de energia, onde teria de usar adaptador. Estão ocorrendo muitos problemas usando o adaptador?
Estava olhando as versões com conector 8 pinos devido o receio, como a ventus 3x, mas devido polêmica recente deixei de lado, estava olhando os modelos da Galax, porque da Asus Tuf está mais caro que o da Msi. Sabem se o modelo da Galax sincroniza com software da Msi caso pegue o Ex?
Mas não usam mesmo conector?Nunca vi relato do problema nas 4070...
Mas o cossumo de energia é beeem menor.eu comprei um original da minha fonte pra uso com a 4080 apenas porque achei o adaptador fornecido de 3 pontas feio,uma gambiarrra,mas por eficiencia não precisaria.relatos de bo só com a 4090.Mas não usam mesmo conector?
Pior que pra minha fonte creio que não tenha o cabo que substitui o adaptador, uso uma xpg core reactor 650w. E o encaixe do conector é tranquilo de encaixar? Fácil de sair da vga?Mas o cossumo de energia é beeem menor.eu comprei um original da minha fonte pra uso com a 4080 apenas porque achei o adaptador fornecido de 3 pontas feio,uma gambiarrra,mas por eficiencia não precisaria.relatos de bo só com a 4090.
Galera, andei vendo nos sites as garantias das placas da linha 40 e tudo dizendo 12 meses.
MSI também tudo 12 meses
Mudou algo sera?
Esses primeiros 12 meses algumas lojas podem intermediar o serviço de garantia pra vc direto com suporte do fabricante.Galera, andei vendo nos sites as garantias das placas da linha 40 e tudo dizendo 12 meses.
Mudou algo sera?
