Pegando aqui hahaha. Valeu!!Hey, aquele Caribe, sabe, aquele que fica na russia, acabou de atualizar pro beta 4, hahaha. Yar!
Estranho, aqui entra super de boa. Segue como instalar (não tem o link para o mod porque não sei se quebra alguma regra, então estou evitando links haha)Não consigo acessar o site, da algum erro de proxy.
- Remember to delete d3d12.dll AND dxgi.dll in the game's root folder if you have installed any other version of the mod.
- Extract to game's exe folder, if you have been using ReShade, don't overwrite the ReShade.ini so that you can use your own preset.
- If you want the Steam Overlay or your controller is not working, rename d3d12.dll to dxgi.dll.
- Enable FSR2 and disable Dynamic Resolution in the game settings.
- Disable in-game VSync! It might crash when the setting will be saved
- Press END to open the menu, then authenticate for the first time, no continuous subscription needed, if you have subscribed you can pass the authentication after the subscription expires.
- Enable DLSS2 and DLSS FG in the mod menu.
- There's hotkey for toggling them, and you can change them in the mods/StarfieldUpscaler.ini.
