Acha que vale mais uma Zotac 780 Amp por enquanto?
a se tu for de 780 ja fique de uma vez oras,não teria lógica em trocar depois
Bom... Melhor lançar algo estável e que traga algum benefício do que lançar algo que trará mais problemas do que qualquer outra coisa.
Abçs
verdade mesmo porque ninguém quer outro Battlefield 4.
GTX 780 | GTX 780 Ti | GTX Titan | R9 290X | |
Assassin's Creed IV | 19.7 | 24 | 21.8 | 24.9 |
Batman Arkham Origins | 56.7 | 67.9 | 61.6 | 57.3 |
Battlefield 3 | 40.7 | 48.8 | 44.4 | 49 |
Battlefield 4 | 25.8 | 31 | 28 | 31.6 |
Bioshock Infinite | 47.9 | 56.1 | 52.8 | 53.4 |
Call of Juarez Gunslinger | 100.6 | 120.4 | 108.3 | 131.1 |
Crysis | 25.8 | 30.1 | 28.4 | 31.9 |
Crysis 3 | 14.9 | 17.5 | 16.6 | 18.4 |
Far Cry 3 | 20.1 | 23.8 | 21.4 | 22.5 |
GRID 2 | 49.3 | 61.1 | 55 | 62.4 |
Metro Last Light | 27.6 | 34.6 | 30 | 34.1 |
Splintercell Blacklist | 30.7 | 36.7 | 32.4 | 26.4 |
Tomb Raider | 16.6 | 21 | 19 | 21.6 |
R9 290X vs GTX 780 | R9 290X vs GTX Titan | R9 290X vs GTX 780 Ti | |
Assassin's Creed IV | 126.40% | 114.22% | 103.75% |
Batman Arkham Origins | 101.06% | 93.02% | 84.39% |
Battlefield 3 | 120.39% | 110.36% | 100.41% |
Battlefield 4 | 122.48% | 112.86% | 101.94% |
Bioshock Infinite | 111.48% | 101.14% | 95.19% |
Call of Juarez Gunslinger | 130.32% | 121.05% | 108.89% |
Crysis | 123.64% | 112.32% | 105.98% |
Crysis 3 | 123.49% | 110.84% | 105.14% |
Far Cry 3 | 111.94% | 105.14% | 94.54% |
GRID 2 | 126.57% | 113.45% | 102.13% |
Metro Last Light | 123.55% | 113.67% | 98.55% |
Splintercell Blacklist | 85.99% | 81.48% | 71.93% |
Tomb Raider | 130.12% | 113.68% | 102.86% |
Média | 123.49% | 112.32% | 101.94% |
GTX 780Ti vs GTX 780 | |
Assassin's Creed IV | 121.83% |
Batman Arkham Origins | 119.75% |
Battlefield 3 | 119.90% |
Battlefield 4 | 120.16% |
Bioshock Infinite | 117.12% |
Call of Juarez Gunslinger | 119.68% |
Crysis | 116.67% |
Crysis 3 | 117.45% |
Far Cry 3 | 118.41% |
GRID 2 | 123.94% |
Metro Last Light | 125.36% |
Splintercell Blacklist | 119.54% |
Tomb Raider | 126.51% |
Média | 119.75% |
GTX Titan vs GTX 780 | |
Assassin's Creed IV | 110.66% |
Batman Arkham Origins | 108.64% |
Battlefield 3 | 109.09% |
Battlefield 4 | 108.53% |
Bioshock Infinite | 110.23% |
Call of Juarez Gunslinger | 107.65% |
Crysis | 110.08% |
Crysis 3 | 111.41% |
Far Cry 3 | 106.47% |
GRID 2 | 111.56% |
Metro Last Light | 108.70% |
Splintercell Blacklist | 105.54% |
Tomb Raider | 114.46% |
Média | 109.09% |
Vcs acham que uma r9 290 custom terá mais desempenho que uma gtx 780 custom como uma zotac amp! Edition ou uma windforce?
XFX R9 290X R.i.P
Tava jogando SimCity...
Do nada o PC desliga....
OK tento ligar, ele Pisca e desliga novamente...
abro a tampa do gabinete e vem aquele leve cheiro de transistor queimado....
Bom.. por onde começar.. removi a VGA
tentei ligar e ele ligou, apitou falta de VGA...
Troquei de slot, mesma coisa, alterei a BIOS da VGA para Quiet mode...
O PC ligou mas travou no Led da VGA, sem post...
novamente o cheirinho veio a tona, desliguei o PC
troquei a VGA por uma velha gerreira eVGA GTX 260
E estou escrevendo esse post agora com ela
Que azar amigo, não poderá ser a fonte?
XFX R9 290X R.i.P
RMA nela, não?
Aproveita e atualiza aqui no tópico todo o processo de troca para ver se a kabum é boa na hora que precisamos da garantia.Comprei na Kabum a 1/2meses
Vou ligar para eles amanhã
(...)abro a tampa do gabinete e vem aquele leve cheiro de transistor queimado(...)
analisando a placa, o cheiro de queimado vem ( ou aparentar vir) na parte próxima aos conectores VGA/DV-i & Cia...
será que foi VRM das memorias?
XFX R9 290X R.i.P
XFX R9 290X R.i.P
E vc usava algum profile nos fans pra nao deixar a temperatura passar dos 80-85? ou deixava tudo no auto?
E ae galela, preciso da ajuda de voces.. tenho uma vga r9 290 da xfx modelo de referencia e hoje eu percebi que quando eu abro o gpu-z no campo da memoria a memoria dedicada está ficando como 0 e no campo da memoria dinamica esta com o valor variavel mesmo em load... Eu estou usando o windows 8.1 como que esta no de voces ai? eu estou achando que a memoria morreu.. tambem ja desinstalei o drive e instalei novamente e nada..
Olhem ai na imagem
http://i42.tinypic.com/j0h087.jpg
Sim, pouco tempo antes estava com menos de 400w de consumo ( já tive 620w de pico jogando BF4) e a temperatura da placa estava em 73c
Lembro que a minha também estava com 0 na memoria, mas nem liguei pra isso
Seria Bug
meus pesames browXFX R9 290X R.i.P
e a pergunta que não quer calarEntrei em contato com a Kabum agora a tarde, de manhã não atendiam o telefone
Já abriram um RMA e me enviaram os dados para envio.
Já foi enviada agora pouco.
XFX R9 290X R.i.P
