Sim, vi na hora que era problema pq no 2º teste foi no servidor do próprio provedor.
Agora:
Código:
PS C:\ookla-speedtest-1.2.0-win64> .\speedtest.exe speedtest -p yes
   Speedtest by Ookla
      Server: GOX CONECT - Suzano (id: 27588)
         ISP: O.i Adeyeye Comercio
Idle Latency:     2.47 ms   (jitter: 0.20ms, low: 2.25ms, high: 2.70ms)
    Download:   822.86 Mbps (data used: 829.2 MB)
                  5.65 ms   (jitter: 4.59ms, low: 2.20ms, high: 212.29ms)
      Upload:   759.18 Mbps (data used: 352.4 MB)
                 50.13 ms   (jitter: 10.11ms, low: 2.16ms, high: 121.78ms)
 Packet Loss: Not available.
  Result URL: https://www.speedtest.net/result/c/cb4a9bab-80d6-4847-86ea-9629f5dea932
PS C:\ookla-speedtest-1.2.0-win64> .\speedtest.exe speedtest -p yes -s 39743
   Speedtest by Ookla
      Server: WOW! Fiber - Suzano (id: 39743)
Idle Latency:     4.25 ms   (jitter: 0.15ms, low: 4.21ms, high: 4.43ms)
    Download:   939.19 Mbps (data used: 980.1 MB)
                  8.24 ms   (jitter: 3.10ms, low: 4.07ms, high: 217.32ms)
      Upload:   758.73 Mbps (data used: 362.0 MB)
                 41.31 ms   (jitter: 7.55ms, low: 4.66ms, high: 119.92ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/87a2ff34-4f91-4052-ade4-e6c19b6e3960
Qual navegador vc usou para fazer os 2 primeiros testes?
encontrei isso na internet: VLAN_MANU_MODE
ValueModeNoteExplaination
0Transparent ModeVLAN will mapped as isMap VLAN without changing original id
1Tagging ModeVLAN Stacking / Q-in-QUntag first VLAN layer and bridge as is
2Remote Access Mode
3Special Case Mode
A propósito, testei as opções para a onu V-SOL V2802RH, não funcionou. Tentei com bridge, sem bridge, com vlan e sem vlan setada. Resultado... sem pppoe server na vlan 100 do meu provedor. Para voltar tive que restaurar do backup das config.
Código:
AP#cfgmib get VLAN_MANU_MODE
<Name="VLAN_MANU_MODE" Value="0x0"/>
AP#cfgmib get VLAN_CFG_TYPE
<Name="VLAN_CFG_TYPE" Value="0x0"/>
AP#cfgmib set VLAN_CFG_TYPE 1
<Name="VLAN_CFG_TYPE" Value="0x1"/>
AP#restart
Modem is restarting...
Estava torcendo para dar certo, ia ser mão na roda para gerenciar as vlans no meu mikrotik
chrome
Será que tem algo errado com a V-SOL V2802RH @KILLME @_Piccini_ @FabianoSR?
Até mostra uns picos de 1.300Mbps mas logo depois cai para no máximo 1Gbps cravado.
Código:
AP#diag
RTK.0> port get status port all
Port Status Speed    Duplex TX_FC RX_FC
0    Up     2.5G     Full   Dis   Dis
1    Down   10M      Half   En    En
2    Up     1000M    Full   Dis   Dis #<--------Mikrotik mostra 2.5Gbps
RTK.0> bandwidth get ingress port all rate
port: 0 rate:4194296
port: 1 rate:4194296
port: 2 rate:4194296
Teste de velocidade com servidor na porta de sfp+ 10Gbps
Código:
root@pve:~# speedtest -p yes -s 36386
   Speedtest by Ookla
      Server: TIM Brasil - São Paulo (id: 36386)
         ISP: Gox Conect
Idle Latency:     3.99 ms   (jitter: 0.08ms, low: 3.89ms, high: 4.05ms)
    Download:   999.42 Mbps (data used: 1.2 GB)
                  4.21 ms   (jitter: 1.98ms, low: 2.97ms, high: 11.74ms)
      Upload:   728.80 Mbps (data used: 490.4 MB)
                  3.58 ms   (jitter: 0.38ms, low: 3.00ms, high: 4.26ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/b60b169d-bfe3-453b-a2a4-203d5f1        dd006
   Speedtest by Ookla
         ISP: Gox Conect
Idle Latency:     1.94 ms   (jitter: 0.08ms, low: 1.85ms, high: 2.08ms)
    Download:   598.90 Mbps (data used: 568.1 MB)
                  9.83 ms   (jitter: 2.19ms, low: 2.48ms, high: 17.30ms)
      Upload:   679.24 Mbps (data used: 317.6 MB)
                  2.06 ms   (jitter: 0.76ms, low: 0.90ms, high: 3.96ms)
  Result URL: https://www.speedtest.net/result/c/bdd79b83-5a60-4595-93f5-f05c98f        030b2
root@pve:~# speedtest -p yes -s 22028
   Speedtest by Ookla
      Server: World Fast Telecomunicações - Mauá (id: 22028)
         ISP: Gox Conect
Idle Latency:     4.02 ms   (jitter: 0.12ms, low: 3.92ms, high: 4.17ms)
    Download:   940.49 Mbps (data used: 459.1 MB)
                  6.30 ms   (jitter: 0.32ms, low: 4.28ms, high: 7.19ms)
      Upload:   719.26 Mbps (data used: 608.2 MB)
                  3.85 ms   (jitter: 0.40ms, low: 3.14ms, high: 4.86ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/72fec872-40b5-4f23-931e-45a7190        5be1c
root@pve:~# speedtest -p yes -s 39743
   Speedtest by Ookla
         ISP: Gox Conect
Idle Latency:     3.96 ms   (jitter: 0.12ms, low: 3.86ms, high: 4.08ms)
    Download:   994.36 Mbps (data used: 1.3 GB)
                  3.67 ms   (jitter: 0.48ms, low: 3.05ms, high: 11.84ms)
      Upload:   667.52 Mbps (data used: 741.6 MB)
                  3.77 ms   (jitter: 0.55ms, low: 3.10ms, high: 12.69ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/ccda309b-0d5a-4646-b0a4-6763bd3        3afe8
Agora:
Código:
   Speedtest by Ookla
   Speedtest by Ookla
 Packet Loss:     0.0%
Poderia testar neste servidor conectado tanto na porta 1Gb quanto na 2.5Gb?
ID 11515
Eu já tinha testado estes comando de alterar a banda no firmware 1.16 e não funcionou.
Os chinas desenvolveram um aplicativo para customizar as informações da ONU VSOL:
2023-09-24-15-19-58-Lan-ada-ferramenta-de-depura-o-dedicada-de-modem-ptico-universal-VSOL-gateway.png
:money:
ID 11515
:money:
como funciona esse App? e teria alguma vantagem sobre editar pelo telnet?
Eu imagino que criaram um programa que onde você só preenche os dados que você quer setar na ONU VSOL e o programa se encarrega de conectar a ONU via telnet e rodar os comandos necessários para as devidas alterações requisitadas. Ou seja, ele facilitaria a configuração da ONU VSOL.
Qual página você quer acessar? Se for essa página abaixo dá para liberar editando o HTML via Chrome Inspector, mais detalhes no meu post aqui.
Exatamente esta página, porém tem um pequeno problema... Eu não consigo enviar o comando via telnet para listagem de VLAN, infelizmente essa ONU da tp-link não me da esse acesso e a VLAN 200 da OI (Vtal) não funciona, creio que seja outra VLAN que fica mascarada na OLT.
ID 11515
Segue:
*Edit: Não teve diferença tanto na porta de 1 ou 2,5Gbps dois resultados muito parecidos, somente o bug com os testes cli da ookla.
Resultado do meu pc:
Estão filtrando os testes via cli ou o app da ookla ta bugado, Olha isso
Código:
   Speedtest by Ookla
      Server: AT&T - Miami, FL (id: 47746)
         ISP: Gox Conect
Idle Latency:   147.48 ms   (jitter: 0.06ms, low: 147.40ms, high: 147.60ms)
     Latency: FAILED
[error] Cannot open socket
   Speedtest by Ookla
         ISP: Gox Conect
Idle Latency:     3.97 ms   (jitter: 0.04ms, low: 3.97ms, high: 4.04ms)
    Download:   994.77 Mbps (data used: 1.2 GB)
                  4.11 ms   (jitter: 14.05ms, low: 3.90ms, high: 209.06ms)
      Upload:   806.87 Mbps (data used: 808.0 MB)
                  3.64 ms   (jitter: 0.35ms, low: 3.02ms, high: 4.53ms)
  Result URL: https://www.speedtest.net/result/c/8e3b1956-4da1-4545-bf68-8400ba77a040
root@pve:~# speedtest -p yes -s 11515
   Speedtest by Ookla
      Server: Grupo GTD - Miami, FL (id: 11515)
         ISP: Gox Conect
Idle Latency:   107.48 ms   (jitter: 0.07ms, low: 107.43ms, high: 107.53ms)
    Download:  1003.41 Mbps (data used: 1.4 GB)
                163.49 ms   (jitter: 54.23ms, low: 107.86ms, high: 337.64ms)
      Upload:    49.27 Mbps (data used: 86.5 MB)
                177.78 ms   (jitter: 57.80ms, low: 118.55ms, high: 237.10ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/bdec53d6-48d6-4014-98ff-e33b38deae22
   Speedtest by Ookla
         ISP: Gox Conect
Idle Latency:   107.75 ms   (jitter: 0.07ms, low: 107.66ms, high: 107.81ms)
    Download: FAILED                                            cy: 200.94 ms
ID 11515
:money:
Link?
Segue:
Código:
   Speedtest by Ookla
         ISP: Gox Conect
     Latency: FAILED
   Speedtest by Ookla
         ISP: Gox Conect
   Speedtest by Ookla
         ISP: Gox Conect
 Packet Loss:     0.0%
   Speedtest by Ookla
         ISP: Gox Conect
Eu queria ver se iria capar o upload na porta 2.5Gb que é bug que existe atualmente. E não afeta somente speedtest mas também upload para serviços cloud como iDrive.
Um dos testes que você postou mostrou exatamente isso. O upload capada a cerca de 50Mb.
Se conseguir se cadastrar no fórum e baixar o arquivo posta aqui.
Baixar nunca irei conseguirei, mas estou desenvolvendo um projeto parecido... só que pra ONTs Huawei
Agora se eu irei finalizar algum dia? num sei :haha:
@KILLME , ainda consegue baixar arquivos deste fórum chinês? Soltaram mais uma atualização de firmware:
Olha o comentário do china à respeito da versão 1.1.7 (só não se ele se refere a versão anterior ou essa nova que soltaram dia 19/09):
2023-09-20-22-36-52-O-firmware-mais-recente-do-modem-ptico-VSOL-V2802-RH-foi-substitu-do-por-123pa.png
Nesse aí eu não consigo, só no chinaadsl
Alguém já conseguiu baixar essa versão mais recente do firmware 1.1.7-9.11 do VSOL?
Meus queridos, só pra confirmar: eu pegando a vsol que é upc, não tem problema em ligar na v.tal que é apc, confere? A única coisa que pode acontecer é um aumento/perda nos sinais, é isso? Pq o adaptador eu quero comprar depois. Só pra ver se vai funcionar com deve no meu caso.
]Meus queridos, só pra confirmar: eu pegando a vsol que é upc, não tem problema em ligar na v.tal que é apc, confere? A única coisa que pode acontecer é um aumento/perda nos sinais, é isso? Pq o adaptador eu quero comprar depois. Só pra ver se vai funcionar com deve no meu caso.
Não confere. Você não deve conectar APC com UPC. O corte da fibra é fisicamente diferente. Pode funcionar com degradação do sinal e até danificar a ponta na fibra do conector, portanto não recomendado de forma alguma. O uso de um adaptador APC-UPC nesse caso da VSOL é obrigatório.
images
Não confere. Você não deve conectar APC com UPC. O corte da fibra é fisicamente diferente. Pode até danificar a ponta na fibra do conector. O uso de um adaptador APC-UPC nesse caso da VSOL é obrigatório.
images
Solução baratinha:
No momento estou utilizando um Fiberhome HG6145F em bridge, internet de provedor local. Velocidade contratada de 600 mbps.
O problema é que a cada 3/4 dias a velocidade de download cai pela metade, reiniciando volta à velocidade normal. Eu pensava que colocando em bridge resolveria isso.
A minha dúvida é se trocar esse Fiberhome por um TP-Link xz000-g7 resolveria esse problema.
Tem certeza que é a Onu?
Pode ser o router, talvez.
Nesse caso deve ser 100% essa bombahome o problema, visto que é uma das piores marcas de ONTs de baixo orçamento.
Pessoal, alguém conhece alguma ONU/ONT seja o preço que for que trabalhe com link de 2.5gb? Toda minha infra é 10Gb, switchs, PC, NAS etc.
Me falta agora um router wifi7 (já determinei o modelo) e uma ONU/ONT de pelo menos 2.5gbs pois meu link de provedor é de 2gigas.
Seu provedor usa GPON? Se for tem a VSOL V2802RH que vários aqui estão usando.
Esse V2802RH é o curinga master do momento, pega em todos os provedores praticamente, principalmente depois do novo firmware do Triple :limo:
Sim, já até utilizo um TPLink G7. Aproveitando, eu uso LiveTim aqui no RJ.
Eu tenho um VSOL parado aqui pois o TPLink G7 é praticamente plug&play, inclusive é usado em bridge, mas só suporta conexão de 1Gb.
Não vi ninguém aqui no RJ usando VSOL com a Tim. Na Vivo me parece que tem.
VSOL suporta link de 2.5gb?
Eu tenho um VSOL parado aqui pois o TPLink G7 é praticamente plug&play, inclusive é usado em bridge.
Ela tem porta de 2.5Gb além da porta 1Gb.
