Consegui voltar meu save game
How To Fix Far Cry 3 - Save Game
For anyone who had trouble with the save issue on Far Cry 3
Here is the Solution How to Fix This
First of All you should have Far Cry 3 and Uplay installed
if you have ( no matter what version of Uplay or Far Cry ) that installed we can start
Step 1.
Open your Far Cry 3 Folder then enter "bin" and you should have a file called "orbit_api" , opet it with notepad and change the game id to 48
Step 2.
Open your Uplay Folder , for example mine is Crogram Files ( x86 ) / Ubisoft/ UbisoftGameLauncher , after you enter that folder you will see another folder called "data" Open it
Step 3.
Search for a Folder that has the number 46 and rename it to 48 , like your game id ,
Step 4.
deu certinho aqui!!!
se essa desgrama der pau de novo...
Enter the game and save as well autosave should work , you will not be able to unlock achievements because you took the game id form an other game but your save will work perfectly
Step 1.
Step 2.
Step 3.
Step 4.
