Tô que nem criança, permitam-me compartilhar minha alegria de crianção de meia-idade (cortem meu barato não) que posta no Adrena do trabáio com um monte de coisas pra fazer (é isso e FUI, tô ficando nervoso já).
DIA FELIZ! DEMOROU MAS CHEGOU!
ME SEGUREM! VOU SAIR CORRENDO DO TRABALHO!!!
LIGUEI PRA CASA PRA SABER SE O CORREIO TINHA ENTREGADO ALGUMA COISA: a empregada disse que chegaram dois pacotes: um do "môuses" (que maldade, eu não presto) e outro das Americanas.
Significa que MEU MOUSE, MOUSEPAD
E O GAMEPAD (VÍDEO ABAIXO) CHEGARAM!!
http://static.zenimax.com/forums.bethsoft.com/public/style_emoticons/default/celebration.gif http://static.zenimax.com/forums.bethsoft.com/public/style_emoticons/default/banana.gif
E bem a tempo, pois hoje à noite começo a jogar o Mass Efect 3 que deixei baixando lá em casa!! LIKE A BOSS! ![Fuck yeah! :fuckyeah: :fuckyeah:](/styles/dark_responsive/xenforo/menes/fuckyeah.png)
ADAM, ESPERANDO AINDA RESPOSTA DO EXTRA, OK? MAS FICA FRIO QUE TÁ VINDO AÍ!
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If someone told you that there's no difference between the Xai and the Kana, they're not an expert. The Kana uses a Pixart sensor that's decent enough in terms of maximum perfect control speed, acceleration, LOD, and jitter. The Xai uses the overrated and overly expensive Avago ADNS-A9500 with a custom lens. It has a very low LOD but its perfect control speed is horridly low. At relatively low speeds it suffers from unpredictable positive acceleration making precise flick shots more luck than skill. If you play at over 8cm/360 the Xai is a horrible choice for a mouse."
OWNED!
BRINQS!
