Eu tinha, desinstalei porque tava estuprando meu ssd sem necessidade.Vale a pena baixar esse ultra hd texture pack? pra jogar em full hd (ultra wide)?
Graficamente muda algo?Eu tinha, desinstalei porque tava estuprando meu ssd sem necessidade.
Se jogar Casual, simVale a pena baixar esse ultra hd texture pack? pra jogar em full hd (ultra wide)?
Operators
Maps
- Lesion - Defender
- Deploys a mine that goes off when an attacker steps on it
- Confirmed, Gu is pronounced "goo" mine
- New Mine every 35 seconds
- Start with 2
- Stepping on mine does a damage, then damage over time, prevents people from sprinting. Dart can be removed by pressing a key after stepping on it
- UI shows mines are, and when the mines are removed (either by going off or being destroyed)
- 2 Speed, 2 Armor
- Silenced shotgun (like how echo works), and SMG
- Impact and deployable shield
- How it will be interact with other operators
- Montagne must de-activate his ability to remove mine from leg
- Season Pass uniform
- Ying - Attacker
- Deploys a ball that flashes defenders (and other attackers other than Ying)
- Can throw her ability to use it like a stronger normal flashban
- She is still affected by normal flashes
- Can be planted on walls like fuze's charge
- Can also be used in a Timer mode, letting the gadget roll then detonate. Will follow the edges of walls and go through drone holes
- 2 Speed 2 Armor
- LMG and Same shotgun that Lesion has, but without silencer
- Claymore and Smoke
- How it will interact with other operators
- Ela - Defender
- Trapper that throws traps that stick to surfaces and detonates when attacker comes close
- Gadget sticks to walls Ceilings and Floors
- Slows how quickly operators can rotate
- Lowers Field of view
- Can use the ability when downed on herself
- Three Speed, 1 Armor
- Shotgun, SMG, and red dot on her pistol
- Impact and Barbed wire
Game Changes
- Theme Park
- Second Floor - https://i.imgur.com/ak0dE4d.png . Red is destructible floors
- First Floor - https://i.imgur.com/CIqMH2G.png
- Map has a 2 Building style with a middle connector (reminds me of skyscraper's overall layout)
- Meth Lab Confirmed
- Overall the map is darker than most (if not the darkest map)
- Smoke confirmed buffed, harder to see through, more consistent
- TTS will be used in seasonal updates going forward
Preciso de ajuda, eu baixei o jogo pela uplay, joguei e gostei, então comprei na steam que é a plataforma que uso normalmente, a minha dúvida é, eu vou precisar baixar o jogo mais uma vez ?
Tentei algumas formas de fazer a steam reconhecer mas todas falhas, HELP ! :/
Sim, vai precisar baixar de novo.Preciso de ajuda, eu baixei o jogo pela uplay, joguei e gostei, então comprei na steam que é a plataforma que uso normalmente, a minha dúvida é, eu vou precisar baixar o jogo mais uma vez ?
Ativa a opção para mostrar o fps, pode ser isso.. Aqui depois que atualizou ficou caindo muito o fps, eu vejo o canal do patife e ele tb teve esse problema pelo visto..
Por versão completa penso que vc se refere a pegar o jogo com Season Pass?Galera, to testando o game e curti. Minha duvida é, vale a pena pagar o dobro pra pegar a edição completa?
que merda, meu notebook começou a dar queda de fps de novo, 2 dias seguidos ja.. um amigo meu tem o not com a placa inferiror e o mesmo processador, e lá fica estávelEntao, resolvi praticante desinstalando o jogo por completo. Cheguei a pensar que fosse o mouse, mas como troquei de mouse e continuou, testei formatar a unidade C onde fica o Windows e também nada. Deletei o jogo por completo, todos os arquivos instalados e iniciei a instalação do zero e resolveu
Se for isso, depende muito do seu tempo pra jogar. O que o season pass faz é te liberar os agentes de graça e uma semana antes. Caso não se importe com isso, vc ainda pode liberar os agentes com dinheiro do jogo, 25k, que demora um pouco pra conseguir, mas dá tranquilo.
Hoje já foi mais aturável, sexta era eu + 4 recrutas no squad hahahahaEsse tempo de jogo grátis e um caos pra defender os caras morre em 1 segundo.
Galera tem canal no discord pra galera aqui do fórum? Curti demais o jogo tanto que comprei a edição std, porém jogar só com random sem comunicação complica. Me arrependo de não ter comprado o jogo antes, é bom demais!
Sim, o rank é zerado junto com o update da DLC.Hoje já foi mais aturável, sexta era eu + 4 recrutas no squad hahahaha
@topic
Quando reseta o rank? Dia 5 quando lançar a dlc? Reclamava de meu rank season passada, que eu não merecia ouro, nesta atual terminei md10 em bronze I, consegui chegar em ouro III hoje hahaha a gente vai aprendendo.
O jogo e bom mesmo, me estresso menos nele que no Overwatch acho menos dependente do time, e não vejo tanto trolls.
Se não me engano e esse:
https://discord.me/adrena-r6
Joguei (perdi) algumas ontem, foi engraçado um guri de uns 10 anos falando no voice.Valeu, vou adicionar hoje. Achei a galera bem mais receptiva também nesse game, geralmente no PC eu só trombo com pau no c*...Caras que não se ajudam, não se comunicam. De sexta pra ontem já adicionei uns 2 caras que jogavam direitinho, se comunicando, humildes e receptivos com os novatos.
Ja que BF virou uma espécie de "cidade fantasma", vou me dedicar ao R6 no PC.
Me add lá, Aids_Aegypti (se não me engano)Valeu, vou adicionar hoje. Achei a galera bem mais receptiva também nesse game, geralmente no PC eu só trombo com pau no c*...Caras que não se ajudam, não se comunicam. De sexta pra ontem já adicionei uns 2 caras que jogavam direitinho, se comunicando, humildes e receptivos com os novatos.
Me adiciona lá também. Jogo de noite.Valeu, vou adicionar hoje. Achei a galera bem mais receptiva também nesse game, geralmente no PC eu só trombo com pau no c*...Caras que não se ajudam, não se comunicam. De sexta pra ontem já adicionei uns 2 caras que jogavam direitinho, se comunicando, humildes e receptivos com os novatos.
