Operation Burnt Horizon
Detalhes: https://rainbow6.ubisoft.com/siege/en-us/game-info/seasons/burnthorizon/index.aspx
Main Bugfixes
Gameplay
Shield Operators
Border
Caster Camera
Main Bugfixes
Gameplay
- Fixed – Bulletproof cameras can no longer be deployed underneath a Welcome Mat to make it impervious to bullets.
- Fixed – Bulletproof camera is not destroyed if it is placed underneath electrified barbed wire.
- Fixed – Drone destruction sound effects can be heard clearly through floors.
- Fixed – Ambient sound is louder than intended.
- Fixed – The swapping animation from a gun to a primary gadget can be skipped.
- Fixed – ACOG on the M249 does not accurately show where bullets will land.
- Fixed – Spamming the crouch button will lead to cases where the 1st person view is granted before the model is visible from another point of view.
- Fixed – Frag grenades do not always destroy a barricade near it.
- Fixed – Nitro cell damage was not reliable when placed on certain objects across all maps.
Shield Operators
- Fixed – Guard break animation is not present in kill cam replays if the shield Operator is in motion.
- Fixed – Shield Operators crouching and leaning clip through their shield and can be damaged through it.
- Fixed – Legs of all shielded operators are clipping through the ballistic shield while in prone.
- Fixed – Sometimes Guard Break is cancelled when a player shoots the shield and melee’s at the same time.
- Fixed – The guard break animation displays incorrect behaviour when the shield Operator leans to the side.
- Fixed – The kill cam does not show the meleed stance for shield Operators.
- Fixed – Silent Step’s lowered stance is not replicated in first person.
- Fixed – Attackers are immune to Luison's damage for a few seconds if Caveira cancels the interrogation and shoots that attacker.
- Fixed – Audio cue for Airjab detonation does not always play properly.
- Fixed – No sound when Nomad's Airjab becomes active.
- Fixed – When deploying in player’s blind spot, Cluster Charges will have a delayed explosion effect.
- Fixed – Yokai’s attack lowers FPS when the Operator is near the effect.
- Fixed – When using advanced deployment, camera position returns to default for Yokai drones after following specific steps.
- Fixed – The X-KAIROS pellets positioning is unreliable.
- Fixed – Capitao's asphyxiating bolts can go through Mira’s Black Mirror and kill Operators on the other side.
Border
- Fixed – Explosion sounds are muffled in 2F Security Room when listening from 2F Armory Lockers.
- Fixed – Spamming crouch allow a player to vault through the floor.
- Fixed – Drones can clip through a wall to provide an advantage to Attackers.
- Fixed – Players can use a ledge outside to get inside the courtyard.
- Fixed – The Defuser will remain stuck if dropped in the bush on the corner of the EXT Cafe Terrace with 2F Cafe.
Caster Camera
- Fixed – Appearance for various objects while using the caster camera.
- Fixed – 2-0x0000C004 Session_Not_Found Error when accepting squad invite.
- Fixed – Player receives friendly fire message when using Evil Eye to shoot another Evil Eye.
- Fixed – Elite Mute - SMG-11 is missing Mute Elite’s Royal Fusiliers
- Fixed – Missing promote/demote animation in the result screen at the end of Ranked matches.
- Fixed – MMR points appear as if added from zero at the end of a Ranked match.
