Seria o Tempest axo....
outra: o archer ta onde?
Comprei na nuuvem e não veio PT-BR... só uma dúvida: o jogo tem dublagem PT-BR ou só legenda?
Alguem ai Rodando em uma config tipo a minha..VGA GTX 660ti??? Gostaria de saber do desempenho.
Galera como eu movo a câmera em volta do personagem enquanto caminho SEM precisar segurar o botão direito do mouse? Igual o Elder Scrolls Online?
Não gostei de ter que virar a câmera no A e no D, prefiro virar com o mouse, mas sem segurar o direito.
Outra coisa, quando eu estou clicando e atacando, o ponteiro do mouse fica exposto e eu acabo clicando em outra coisa sem querer, é assim mesmo?
Não sei se já foi postado...
Não instale estes jogos no SSD....
Ctrl C + ctrl V
Dragon Age Inquisition
Lords of the Fallen
FIFA 15
So this text is basically a 1:1 copy of a post by facepunch user Korova:
"Resource monitors for RAM and CPU consumption numbers, memory viewer for trying to figure out what makes it tick and track address issues, SSD analysis tools for those delicious dead blocks and data tracking. Wanna know average number of times parts of LotF exe code are fcked around between RAM and HDD in the span of one hour? 150000 copy/write iterations. That's about 10000 times more than usual. DRM constantly decrypts the game code into the memory and encrypts it back. This is the most bull**** usage of encryption software I've ever stumbled upon. And even though code chunks are quite small (couple of kilobytes per go at worst), they are all stored in one memory block. And playing the game for 4-8 hours(depends on SSD quality) means that you can say goodbye to that block." Source: http://www.rpgcodex.net/forums/index...5#post-3599880
So check your install folder for Origin games. You might want to switch over to your hard disk drive with spinning iron plates instead of sacrificing the life of your solid state drive too early. Denuvo is also used by "Lords of the Fallen" and FIFA 15 so far. I think a lot of games will follow. Actually, this would be a good time for crackers to circumvent this protection method since Denuvo will actively destroy hardware over time. I am waiting for the first complaints and lawsuits due to destroyed hardware caused by Denuvo. Sony should probably put some money on the side for those lawsuits. Source: http://www.rpgcodex.net/forums/index...5#post-3599880
For anyone that isn't following this thing, Denuvo is a DRM that encrypts and decrypts itself while you play the game so it's extremely difficult to crack. If these numbers are true, SSD users are fucked and it isn't doing anyone any favors with their normal hard drives.
New information has come out
From a russian forum: "The game's read\write operations per 40 minutes resulted in 30 GB of data processed. The number of operations done is insane. SSD's wear level hasn't changed though, however, the load is EXTREMELY high, so after, say, 100 hours of gameplay memory blocks will definitely start to wear down."
Screenshot before/after:
i9.pixs.ru/storage/5/1/2/855315e479_7456270_14771512.png
Games that use Denuvo
Lords of the Fallen
FIFA 15
Let's hope the list doesn't grow any longer.
Olha, a minha GTX 660 estava chorando pra rodar aqui.
Consegui rodar mais de boa depois que fiz um arquivo user.cfg com base no do BF4 e deu uma melhorada na performance sem perder muito a qualidade.
Estou rodando no High aqui com AA Multiamostra desligado.
conte-me mais sobre esse CFG, por favor
GameTime.MaxVariableFps 60
PerfOverlay.DrawFps 1
RenderDevice.TripleBufferingEnable 0
RenderDevice.VsyncEnable 0
PostProcess.DynamicAOEnable 0
WorldRender.MotionBlurEnable 0
WorldRender.MotionBlurMax 0
WorldRender.MotionBlurQuality 0
WorldRender.MotionBlurMaxSampleCount 0
WorldRender.SpotLightShadowmapEnable 0
WorldRender.SpotLightShadowmapResolution 256
WorldRender.TransparencyShadowmapsEnable 0
WorldRender.LightTileCsPathEnable 0
RenderDevice.Dx11Enable 1
RenderDevice.Dx11Dot1Enable 0
RenderDevice.Dx11Dot1RuntimeEnable 0
Thread.MaxProcessorCount 4
Galera, eu mudei o diretório do meu SSD para o meu HD mas agora o jogo não inicia fala como se não tivesse instalado
Alguém sabe o que devo fazer?
Mesmo colocando o arquivo de tradução no lugar, não consigo fazer ficar PT-BR... e agora????
300 milhões de bugs e NENHUM pronunciamento da porra da EA,depois eles vem falar de pirataria!!!http://forum.bioware.com/topic/520865-deluxe-editionpreorder-items-missing/
Problema dos itens da deluxe faltando.
Precisa mudar no Origin a pasta dos jogos instalados.
Depois voce vai no origin e começa o downloa do jogo de novo, deixa ficar em 1% depois pausa. Na pasta onde o origin começou o download voce copia a que voce moveu e coloca sobre essa que o origin começou a baixar entendeu? ai voce vai no origin de novo e despausa o download, ele vai ler entender que voce ja fez o download e vai habilitar o jogo pra voce jogar.
Joguei 4horas do jogo e nao abri nem metade do primeiro mapa ainda
espero que saia um patch logo arrumando esses pequenos problemas de todo mundo inclusive o meu
se comprou na nuuvem, nem adianta
Então vou ter que ficar com a versão americana do jogo??? é sério isso???:fuuu:
300 milhões de bugs e NENHUM pronunciamento da porra da EA,depois eles vem falar de pirataria!!!![]()
