Nem fala hahaha. Eu já sou bem lento no jogo porque fico admirando os planetas e sistemas. Serei um bom explorador
Mas vamos ver né, de repente nesse update algum sistema deve dar bastante dinheiro, além das missões de passageiros.
Saiu um novo updatzinho agora pouco.
- Don't crash if there's invalid state in the powerplay map
- Fix crash when looking at the role panel in the SRV
- Protect against crash from an empty journal message
- Prevent spinning ship while docked and using VR mode with Rift CV1
- Fix a crash that can happen if the persistent POI generation runs before the planet surface controller is ready
- Fixed SRV starting underground if the base is in a crater
- Fix soft lock when entering installations when another player is already at the installation
- When cannons, plasma accelerators and railguns malfunction, they now deal 5% of their own damage to themselves, rather than 200% which would instakill them
- Civil wars now use the same structure as War/War Support to guarantee there is always at least one conflict zone in civil wars
- Fix an issue with station guns not causing damage in some network conditions
- Hunter hostiles now obey the same cooldown as normal NPCs to prevent instant interdictions
- Fixed an issue where delivery and delivery founder missions were showing the wrong credit reward in the first transaction tab after you accept the mission
- Fixed overhead per system being too large as it's not counting fortified systems towards the number of systems that pay overheads
- Materials do not drop from Fumaroles (or other persistent POIs) when multiple players are present fixed
- Stop prosecuting crimes committed by dead Commanders
- Fixed Commanders allowed to equip multiple fuel scoops, fighter bays, refineries and shield generators by retrieving a module from storage
- Fixed some stored ships not being available within the Shipyard
- Fighter Cockpit UI: removing useless indicators in the bottom right corner, leaving the component's frame only for silent running and wanted status display
- Added message when main ships power plant is malfunctioning will be displayed when player is in both main ship and fighter
- Fine now given for shooting in no fire zone with a fighter
- Lower panel shows SRV that isn't owned fixed
- Fixed missing targeting schematic images for the Satellites
- Starport UI: fixing research panel (numeric stepper) not releasing focus when pressing left on a pad to get back to contacts menu (or back button)
- Change order of string returned by GetLongLatString, to Lat then long to revert the order of the latitude and longitude readout on the hud to be the same as pre-2.2
- Fixed missing Imperial Clipper vibrant paintjobs
- Reduced module and ship transfer distance costs by 50%
- Removed build watermark.
