AMD Software: Adrenalin Edition 23.9.2 Release Notes
Article Number
RN-RAD-WIN-23-9-2
New Feature Highlights
- New Game Support
- Lies of P
- Party Animals
- The Crew™ Motorfest
- Additional SDK Support
- New AMD Radeon™ Anti-Lag+ Game Support
- AMD Software: Adrenalin Edition 23.9.2 introduces Anti-Lag+ support for Starfield, Witcher 3, ELDEN RING and Immortal of Aveum™.
- Up to 45% decrease in latency across select titles when AMD Radeon™ Anti-Lag+ is on, using AMD Software: Adrenalin Edition
23.9.2 on the Radeon™ RX 7900 XTX GPU in select titles, versus when AMD Radeon Anti-Lag+ is off.RS-597
- AMD Radeon™ Anti-Lag+ features an onscreen overlay that can be used to display the system latency of supported games. When Anti-Lag+ is enabled, the onscreen overlay can be toggled on using ALT+SHIFT+L hotkey.
- Toggling the hotkey will first enable the status indicator of Anti-Lag+ (a white triangle), and then display latency in ms or number of frames.
- To compare the difference between Anti-Lag+ and Anti-Lag, hold the DEL key. To compare the difference between Anti-Lag+ On and Off, hold the right CTRL key.
- Use the ALT+SHIFT+F hotkey to monitor FPS when Anti-Lag or Anti-Lag+ is enabled in the game.
Fixed Issues
- Application crash may be observed while playing Baldur's Gate 3 with Vulkan® API set on some AMD Graphics Products, such as the Radeon™ RX 7900 XTX.
- GPU Clock may be artificially limited to 2700 MHz when performing manual tuning on Radeon™ RX 7700 XT and RX 7800 XT graphics.
- Display may not reach correct brightness with certain games on select SAMSUNG™ FreeSync Premium Pro monitors or TVs with local dimming setting enabled.
- Application crash or driver timeout may be observed while playing SMITE® on some AMD Graphics Products, such as the Radeon™ RX 7900 XTX.
- Intermittent application crash or driver timeout may be observed while playing F1® 23 on some AMD Graphics Products, such as the Radeon™ RX 7800 XT.
Known Issues
- Performance Metrics Overlay may report N/A for FPS on various games.
- Audio may intermittently become out of sync with video when recording from AMD Software: Adrenalin Edition with AV1 codec.
- The display may intermittently freeze after changing the encoding format while streaming select games using AMD Link. Users experiencing this issue are suggested to select the desired encode format before streaming as a temporary workaround.
Important Notes
- Factory Reset has been temporarily disabled as a precautionary measure while we address isolated installation issues that have been reported during PC upgrades. Users may use AMD Cleanup Utility as a temporary option.
- Users pairing an RDNA based graphics product with either Polaris or Vega based graphics product are recommended to use the AMD Auto-Detect and Install Tool.
Package Contents
AMD Software: Adrenalin Edition 23.9.2 Driver Version 23.20.11.01 for Windows® 10 and Windows® 11 (Windows Driver Store Version 31.0.22011.1008).
The AMD Software: Adrenalin Edition 23.9.2 installation package can be downloaded from the following link:
By clicking the Download button, you are confirming that you have read and agreed to be bound by the terms and conditions of the
End User License Agreement (“EULA”). If you do not agree to the terms and conditions of these licenses, you do not have a license to any of the AMD software provided by this download.
Installing AMD Software: Adrenalin Edition
For detailed instructions on how to correctly uninstall or install AMD Software: Adrenalin Edition, please refer to the following support resources:
NOTE: This driver is not intended for use on AMD Radeon products running in Apple Boot Camp platforms. Users of these platforms should contact their system manufacturer for driver support. When installing AMD Software: Adrenalin Edition 23.9.2 for the Windows® operating system, the user must be logged on as Administrator, or have Administrator rights to complete the installation of AMD Software: Adrenalin Edition 23.9.2.
Radeon Product Compatibility
AMD Software: Adrenalin Edition 23.9.2 is compatible with the following AMD Radeon products.
Radeon™ RX 7900/7800/7700/7600 Series Graphics |
Radeon™ RX 6900/6800/6700/6600/6500/6400 Series Graphics |
Radeon™ RX 5700/5600/5500/5300 Series Graphics |
Mobility Radeon™ Product Compatibility
AMD Software: Adrenalin Edition 23.9.2 is a notebook reference graphics driver with limited support for system vendor specific features.
AMD Radeon™ RX 6800M Series Graphics |
AMD Radeon™ RX 6700M Series Graphics |
AMD Radeon™ RX 6600M Series Graphics |
AMD Radeon™ RX 6500M Series Graphics |
AMD Radeon™ RX 6300M Series Graphics |
AMD Radeon™ RX 5700M/5600M/5500M/5300M Series Graphics |
AMD Processors with Radeon Graphics Product Compatibility
Important Note for Laptop and All-In-One (AIO) PCs
AMD recommends OEM-provided drivers which are customized and validated for their system-specific features and optimizations.
If you experience issues using the AMD Software: Adrenalin Edition driver package downloaded from AMD.com, please install the OEM-provided drivers for full support and compatibility.
AMD Software: Adrenalin Edition does not include support for handheld gaming devices. Users should check with the OEM for device specific drivers.
DESKTOP | MOBILE |
AMD Ryzen™ Processors with Radeon™ Graphics | AMD Ryzen™ Processors with Radeon™ Graphics |
AMD Ryzen™ PRO Processors | AMD Ryzen™ PRO Processors |
AMD Athlon™ Processors with Radeon™ Graphics | AMD Athlon™ Processors with Radeon™ Graphics |
AMD Athlon™ PRO Processors | AMD Athlon™ PRO Processors |
WHQL Results
| Status |
WHQL Test Suite Results | Passed |
WHQL Microsoft Certification | Passed |
Compatible Operating Systems
AMD Software: Adrenalin Edition 23.9.2 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
- Windows 11 version 21H2 and later
- Windows 10 64-bit version 1809 and later
Footnotes
- RS-597 - Testing conducted by AMD as of September 13, 2023, with a Ryzen™ 9 7950X3D, Radeon RX 7900XTX, 32GB DDR5, and Windows 11 Pro, with AMD Software: Adrenalin Edition 23.9.2 with AMD Radeon Anti-Lag+ ON/OFF on various titles including Starfield, Immortals of Aveum, Elden Ring, and The Witcher 3. Game tested at 4k resolution. Performance may vary. System manufacturers may vary configurations, yielding different results.
© 2023 Advanced Micro Devices, Inc. All Rights Reserved.
